T50 gearbox leak
05-24-2011, 07:30 PM
T50 gearbox leak
I thought this was the rear oil seal leaking but it turns out the gearbox is leaking from behind the release bearing retainer.
It looks straightforward to fix but is there anything I should watch out for when doing so ? Anyone seen this problem before ?
Thanks, TC
05-28-2011, 12:13 AM
T50 gearbox leak
Should be straight forward, i just ordered the seal from Toyota aswell as a gasket thats required when changing the seal.. 4 bolts once the box is off!
I've had two gearbox's leak like this, both times i found the engine had no spigot bearing in the back of the crank as someone had put FWD motors in, so perhaps get a spigot bearing too, if required.
05-28-2011, 06:46 PM
T50 gearbox leak
Mine was leaking from the gasket and the oil seal looked ok.
Definately has a spigot bearing, fitted it myself. I can see how the seal could get damaged if the bearing is missing though.
  T50 gearbox totta Crolla 3 4,291 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 12,315 09-12-2019 07:36 PM
Last Post: DidiDex
  4A-GE bellhousing on a 20 spline T50 The Doctor 2 8,742 09-30-2016 03:38 PM
Last Post: The Doctor
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 8,300 11-27-2015 10:06 AM
  T50 Gearbox, Fragile ! hachirokkos 10 16,107 11-12-2015 12:06 PM
Last Post: S.K.
