T50 from a 3A Engine
03-06-2011, 08:43 PM
Hi guys,
I want to know whether the GB from the 3A engine (old Carina) will fit my GZE directly without having to change the Top shaft? My mechanic had checked for a few gearboxes from a 3A and he said that its different.. I want to confirm whether this is correct or not as I thought its a direct fit.. please help.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
03-07-2011, 07:55 PM
anyone??
03-08-2011, 02:47 AM
Japanese Market AA60 Carina came with 3A motor & T50 G/Box with Hydraulic Clutch. If this is the gearbox you are trying to use then yes it will fit directly behind 4AGZE.
Only difference between Carina T50 & AE86 T50 is that the Clutch Fork is located on opposite sides. Japanese Market AE85 Levin/Trueno came with 3A motor but used a K50 gearbox with cable clutch |
03-08-2011, 03:02 AM
umm.. won't the usual problem of the 4AGZE flywheel+clutch combination being too tall still exist? it will fit, only you need to shave a bit on the T50 bellhousing inside.
04-06-2011, 06:12 PM
Got the problem fixed..
Took me ages to find a T50 but finally I did.. No thanks to my fucking mechanic.. Works fine now.. There's changes you need to do to the Bell housing in the TA60 Carina version.. Thanks guys for the help.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
| T50 gearbox | totta Crolla | 3 | 5,429 |
02-25-2022 02:35 PM Last Post: Project D |
| T50 TRD gearset | DidiDex | 7 | 14,033 |
09-12-2019 07:36 PM Last Post: DidiDex |
| 4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 9,544 |
09-30-2016 03:38 PM Last Post: The Doctor |
| T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 9,409 |
11-27-2015 10:06 AM Last Post: Project D |
| T50 Gearbox, Fragile ! | hachirokkos | 10 | 17,921 |
11-12-2015 12:06 PM Last Post: S.K. |
