T50 Transmission Bell Housing
01-05-2010, 03:31 PM
Hello everyone!
2 months ago I bought a T50 from the engine 2T-GEU ![]() And already 3 months worries me the same question: is T50 from 2T-GEU suitable for motor 4A-GE 20V? Or I have to buy this kind of bell: ![]() Give me, please, some info where I can find PCD for 4A-GE engine and 2E-GEU engine? So I could compare them... ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
01-05-2010, 04:14 PM
Nopes, they will not fit sadly. You have to find an A series bellhousing.
Then you have problem no.2. Bellhousing mount on the tranny side is different between T and A series T50s, so the output bearings will not fit. Have to machine a spacer to mount it and mix and match some parts. Also, the extension housing (with the shifter) is in a different location between AE86 and TA22/TE27. So you will need one if mounting in an AE86. Finally the output axle has a different number of splines. So you will need to have a driveshaft made if used in a AE86. Ideally: just use a 4AGE t50 if you are using a AE86/TE7X series chassis. If not, then I can probably find some more detailed links for you. A wheel to steer the front of the car A pedal to steer the rear |
01-05-2010, 09:19 PM
We put a 4A-engine with T50 in Starlet some years ago.
This is how we did it. T-engine bellhousing, A-engine backing plate ![]() need some welding ![]() upper bolts
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
01-05-2010, 09:29 PM
WOW!!!
I did not think that this is so difficult. Now I will look for a new bell. Thank you, friends! ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
01-06-2010, 10:03 AM
I think I would look for the entire gearbox.
Google for the difference between early 20 spline T50s and later 22 spline T50s. There are lots of little differences. Link for you sah! http://www.toymods.net/forums/showthread...T50+spline A wheel to steer the front of the car A pedal to steer the rear |
01-08-2010, 06:03 PM
NoHachi Wrote:I think I would look for the entire gearbox. How do you think is this T50 similar to 4AGE engine g.box?? Because the seller does not know from what motor it's from... ![]() ![]()
01-08-2010, 07:10 PM
Most ae86 t50's I've seen so far had black shifter stick (plastic surrounding in stead of the cromed thing this one has).
For the rest it looks a lot like an AE86 T50 as far as shape is concerned. FABRICA MI DIEM, PVNC! |
01-08-2010, 11:29 PM
Ivan141 Wrote:Most ae86 t50's I've seen so far had black shifter stick (plastic surrounding in stead of the cromed thing this one has). Yes, it is not from AE86. All I could find is the fact that this T50 was from Tertсel. Probably from one like this: [img]http://upload.wikimedia.org/wikipedia/commons/thumb/1/10/'81_Toyota_Tercel_Coupe.jpg/800px-'81_Toyota_Tercel_Coupe.jpg[/img]
01-09-2010, 12:00 PM
The a series T50's have a A stamped on the bellhousing where the circle is (on the vertical face if the gearbox is horizontal, so on this picture it's on the horizontal face)
01-09-2010, 02:58 PM
kitcarfreak Wrote:The a series T50's have a A stamped on the bellhousing where the circle is (on the vertical face if the gearbox is horizontal, so on this picture it's on the horizontal face) Thank you! Did not know this... ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
| Gearbox mount and transmission mount | gh0st | 9 | 5,626 |
05-08-2022 03:28 PM Last Post: totta Crolla |
| T50 gearbox | totta Crolla | 3 | 3,774 |
02-25-2022 02:35 PM Last Post: Project D |
| T50 TRD gearset | DidiDex | 7 | 11,524 |
09-12-2019 07:36 PM Last Post: DidiDex |
| 20v swap bell housing | izanagi | 2 | 5,329 |
12-15-2016 01:12 PM Last Post: pack |
| 4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 8,351 |
09-30-2016 03:38 PM Last Post: The Doctor |
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://g.io.ua/img_aa/large/1323/12/13231252.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://i599.photobucket.com/albums/tt71/collectorsdestination/today522-1.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://i120.photobucket.com/albums/o196/DavidGilson/gilly.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://i33.photobucket.com/albums/d61/Kleemola/Kuva016.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://i33.photobucket.com/albums/d61/Kleemola/2TkytkinkoppaA-sarjankoneeseensovit.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://g.io.ua/img_aa/large/1313/14/13131428.jpg)
![AEU86 AE86 - T50 Transmission Bell Housing [Image: AEU86 AE86 - T50 Transmission Bell Housing]](http://g.io.ua/img_aa/large/1313/14/13131432.jpg)
