Swiss Madman
08-17-2016, 08:27 PM
Swiss Madman
do I spy a Fujitsubo LegalisR???
Dan -
08-17-2016, 09:33 PM
Swiss Madman
(08-17-2016 08:27 PM)oldeskewltoy Wrote:  do I spy a Fujitsubo LegalisR???
No idea, haven't assessed the mods done to the car yet. Here's the description that I got while buying the car:
Code:
1983 / 124,500 km millage / 5MT  / Crash and repair record unknown
PS / Air-con / CD / DVD / Navigation / Toyota genuine body kits / ETC / Low down / No smoking
Painted again with Toyota genuine same color
No circuit drive / Exterior and interior all stock
No crack on dash board /  tower bar front and rear / Revolver ex-manifold / 60mm stainless exhasut
LW flywheel / racing clutch / TRD all mount and bushes / Suspension kits / TRD LSD
Cusco stabilizer front and rear / Racing ratelar rod / Racing brake pads and line and hose
Toh fook / Long hub bolts / Advan A3A wheels / Cusco oil catch tank / Nagai plug wires / New battery
I'm not sure about all these points, for example it can't be repainted, still has the original stickers that are starting to flake due to age.
08-17-2016, 10:37 PM (This post was last modified: 08-17-2016 10:38 PM by Bean.)
Swiss Madman
chances are they painted a big part of the car but not all of it
PS: not so sure on the Toh fook though Big Grin
08-19-2016, 12:54 PM (This post was last modified: 08-19-2016 12:56 PM by KoJl6ACA.)
Swiss Madman
Toh Fook is here)) red rings on front and rear bumpers - tow hook probably, transliteration from katakana may cause this magic...
My car even older than I.
Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD
Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD
08-19-2016, 11:39 PM (This post was last modified: 08-19-2016 11:52 PM by FanIsHere.)
Swiss Madman
Awesome 86, well done mate! Keep it clean and have fun!
[Image: AEU86 AE86 - Swiss Madman]
Follow: The story of my AE86
08-20-2016, 11:43 AM
Swiss Madman
(08-19-2016 11:39 PM)FanIsHere Wrote:  Awesome 86, well done mate! Keep it clean and have fun!
What exhaust and performance mods in your 86?
08-20-2016, 04:22 PM (This post was last modified: 08-20-2016 04:25 PM by FanIsHere.)
Swiss Madman
I bought it almost stock on January and I'm still on the basic repairs.
Exhaust is stock as far as I know, only a cosmetic final (which I don't like).
It has a set of KONIs with APEX springs all around. Stock engine, stock brakes.
I'm willing to restore the brake calipers, buy new rotors and pads and replace the master cylinder, as it leaks.
Then I'm gonna fix the KONIs and buy new springs -probably custom.
I'm also on a hunt of some nice wheels, so I can buy new tires too.
In addition I must buy poly bushings all around, adjustable pan-hard bar and front strut bar.
After these, I'm going to refresh the engine a bit and then collect parts to make a proper 7AG.
02-08-2017, 02:36 PM (This post was last modified: 02-08-2017 07:45 PM by headrush.)
Swiss Madman
Such a nice Trueno Huh best first car ever Cool
I've also got a set of Advan's A3A on mine, impressive lightweight wheels. Handling and steering feel/response was improved vastly when I changed the heavy stockers. Also, loving the brown/red interior.
Enjoy the car with the nice roads you've got in your beautiful country! Thumbs up!
02-09-2017, 01:02 AM
Swiss Madman
(02-08-2017 02:36 PM)headrush Wrote:  Such a nice Trueno Huh best first car ever Cool
I most certainly do enjoy it a lot! Also funny that an AE86 would be my first car, considering I'm significantly younger than the car. It just gives me that special kind of feeling we all love about it.
Also, small update: Got the LSD rebuild kit from Techno Toy Tuning delivered. Will figure out how to lift the car and drop the rear axle as soon as it's a little warmer (0 degrees and rain right now). Will install the C's short shifter next and then clean up the inside of the rear quarter panels from dust and gunk around the drain holes. Still waiting on the upholstery.
02-09-2017, 02:22 AM (This post was last modified: 02-09-2017 02:24 AM by Bean.)
Swiss Madman
A good jack and axle stands will do the trick. You can lift the car on the diff itself and then put the axle stands under the rear jacking point of the sill. Make sure you put a solid blocker in front of the car so it can't roll away. Also have the axle stands at the highest position for better access and enough slack for the axle to drop. Last but not least, in your case it's probably best if you park it forward so you can roll the axle out, rather than pulling it out from the side.
PS: Having the jack still under the diff when removing the dampers helps to remove some tension, just be sure the car remains firm on the axle stands. You should be able to pull her off in a couple hours by yourself.
  papy---------->from swiss papy 9 12,122 10-10-2011 09:47 PM
  New member from Swiss roadrunner 12 14,680 03-02-2008 01:51 PM
  swiss rwd fun donthomaso 14 17,403 06-22-2007 04:32 PM
Last Post: Fallguz
