Sweet wheels on ebay.de
11-11-2004, 06:11 PM
Please mention the rim width along with the ET value. A 14x4j rim ET0 will sit flush with the fenders as well.
Also, changing the offset changes the scrub radius and could have impact on steering effort , tramlining and bumpsteer.....who cares...looks good A wheel to steer the front of the car A pedal to steer the rear |
11-11-2004, 09:19 PM
et 10 to 20 is most practical on a hachi standard rims are 21 by the way
11-11-2004, 09:38 PM
robokill Wrote:et 10 to 20 is most practical on a hachi standard rims are 21 by the wayI run ET 0 in the front, with the NRCA they are ET -25! They do stick out a little but since I run -3.5 deg of camber the top is actually inside the fender In the rear I run ET-6 but my wheels are wider in the rear! They are out of the wheel arch by about 10mm but suspenison is so stiff that it doesn't rub and the tire tread is actually on the inside of the fender! |
11-12-2004, 12:56 AM
What size wheel is that you have in front? how many inch (6J, 7J?)
11-12-2004, 09:33 AM
Ivan141 Wrote:What size wheel is that you have in front? how many inch (6J, 7J?)7J
11-12-2004, 09:38 AM
and 8J in the back! (100 posts,
