Suspensions and stearing setups
01-02-2007, 02:22 PM
dxaqta Wrote:for grip driving i run:
Camber: -3.0
Castor: +4 degrees
Toe: Zero (as i dont really understand toe)
I personally think that 7 and 5kg spring are to stiff.
Yes, I think the same... I will chage it to 6/5 F/R or 5/4 F/R...
what feel you have whit this setup?
___________
Zax I have a problem with camber... I can´t reduce it, because I use it.... My tyres looks like slicks in the exterior Undecided I think I need it or broke my tyres in two weeks
Few time ago I had -1,5º camber and when i change it to 2º I feel less understeer and more grip, Is possible? but i dont want put more camber because I lose brake power in front tires.
I know you have a lot of experience.... I think I can´t put less camber... what front setup do you think is good with this camber?
____________
Mux, yes of course, Toyo CF have the flank (i dont know if is the correct word) very soft and this don´t help to stop the understeer
Regards and thanks! Respect!
[Image: AEU86 AE86 - Suspensions and stearing setups]
01-02-2007, 02:30 PM
how wide are you rims?
i had 205 on a 7" rim, but it was bad!!
now i have 195 on these rims and its so much better. No wierd worn out tires anymore...
01-02-2007, 02:37 PM
DJexor Wrote:how wide are you rims?
195/60/14" in 14x7 konig rewind 0 offset... Confused
Regards
01-02-2007, 02:52 PM
Camber: -3.0
Castor: +4 degrees
i think 6/4 will work better as i belive 5kg rears will cause oversteer, this could be dialled out with damper adjustments, but i think a 4kg will work better...
however, i think you need to look at the other areas that i stated above, why spend money on new springs when u can play with ur dampers for free!!! or get a wheel alignment for 20$!!! even if it doenst work u will lern something about ur suspension Big Grin
and what i have stated above is mostly from personaly expereince and from speaking to knowlegable indivduals
here is a pic to prove it Tongue
[Image: AEU86 AE86 - Suspensions and stearing setups][/img]
01-02-2007, 02:53 PM
abe, konig's 14" offset is -9.
I don't know your kind of driving ability but when I fitted my limited slip differential I noticed a large increase of understeer. I understood that I needed to change my driving style to reduce this handycap.
Best regards
01-02-2007, 03:03 PM
apardal Wrote:abe, konig's 14" offset is -9.
Best regards
Yes of course, when I put the lsd I Know i will have more understeer, and I know I need change my drive style... but the understeer is more hevy than other cars whit my lsd, and If this understeer can be change... why not change it? if I prefer a car only a bit underster or neutral...
My driving ability... I don´t know but not is the worse
Regards
01-02-2007, 03:08 PM
lsd causes fuck all understeer.. u need to get that out of ur head.. there is something wrong with ur suspensino setup
have u tryed any of our sugestions????
01-02-2007, 03:16 PM
dxaqta Wrote:here is a pic to prove it Tongue
Big Grin Yes I see Evil
I don´t have problems change the spring rates, because when you buy coilovers K-sport, they have a suport of springs a lot cheaper... I can buy 2 springs for around 25 € Huh
But this evening i can go to try whit a new set up of alignment.... and if it work good the problem are finish... if don´t work we know that I need search the problem in other part of the car....
at this moment, I think put dxaqta's alignment:
Camber: -3.0
Castor: +4 degrees
Toe: 0
Other setup or suggestion?
Regards
Thumbs up!
01-02-2007, 03:18 PM
u wont get +4 degree with stock castor rods and with 195/50/15 tyres it rubs on your front bar i had to cut mine
01-02-2007, 03:28 PM
BTW..strong LSD's will push the car into understeer..it's a matter of driving the wrong way. It will lock up..driving bioth rear wheels (which causes the car to try and go straight). If your front tyres are not up to the task, they will be overpowered and pushed into understeer.
  Possible turbo setups for the 4age. wannabeadrifter 3 5,909 10-29-2009 06:15 AM
Last Post: wannabeadrifter
  what do you use like suspensions ? Spy 40 54,636 04-14-2009 10:20 PM
Last Post: Uzelac
  What are your ignition timming setups? Rasteirinho 1 3,754 02-27-2008 08:42 PM
Last Post: Rasteirinho
  Electric fan setups Ivan141 22 32,185 01-05-2005 10:55 PM
Last Post: KristianAE86
