					Surreptitious.....
					10-02-2013, 02:53 AM
				 Post: #191 | |||
| Surreptitious..... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/boxwliddownviewedfromback_zps263bd40b.jpg) ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/boxwlidupviewedfromback_zpsa55603fb.jpg) ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/boxfinishedliddown_zpsb4b28052.jpg) ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/boxfinished_zpsf74413fc.jpg)  Dan - You can |  ....  OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 | |||
					10-02-2013, 01:03 PM
				 Post: #192 | |||
| Surreptitious.....
					looking good mate
				 AE86 ex-daily | |||
					10-02-2013, 01:29 PM
				 Post: #193 | |||
| Surreptitious.....
					I like the idea!   Maybe I'll steal the plans, as I dont use the rear seats because of the rollcage   AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar | |||
					03-15-2014, 11:43 PM
				 Post: #194 | |||
| Surreptitious.....
					A bit of an update....    oldeskewltoy Wrote:If you remember my threads on "tuning" to be able to drive around town... well, she no longer needs a special knowledge of her quirks to drive her normally. Over the past 2 years I've driven Surreptitious less than 1500 miles... alot of this was because a certain tuning shop had no idea how to properly set and program the FJO system. Shortly after I swapped in the 6 speed she went back for a "final" adjustment. LONG STORY short.... once I got it back the last time.... I had to "fix" cam timing, and swap in the earlier tune  Move ahead 2 years... Surreptitious goes to Loynings, and is tuned on their steady state dyno. She is "tuned" in each rpm band for power. Off to DEQ(emissions testing) and fails.... 1100 HC, 5.0 CO. I bring her back in, they make a few adjustments, I go back to DEQ... 214 HC, 0.447 CO - She passes  and no new cat required this time....  Now as far as performance.... She idles...(between 1000 and 1100) she idles and doesn't stall when coming to a stop... she idles with all the installed electrical draws on (lights, wipers, heater fan, 100 watt fog lamps) she even idled with the cooling fan on @ the inspection station without stalling or stumbling while the test was being performed... This tune is only a few days old... but so far it has inspired some new confidence... from another forum Wrote:so uhh...after the new tune....whats the power look like WOT was never a problem... she always (with one exception) planted great power... What is odd... I'm only running 2 BTDC degrees of ignition timing... :eek: OPINION: They did the reverse of what I thought to be needed..... I figured more timing (not less) would make it want to idle up.... What they did was feed in the less timing and they opened up the throttle plate a touch. With the throttle plate open, this lowers the pressure in the manifold... and so when there is a change like vacuum being drawn to run the brakes... or a alternator puts a load on the system there is less pressure change in the manifold... less pressure change, less unstable idle.... and so it idles pretty well under loads now. The above is the change after the failed inspection.... BEFORE the failed inspection... They did a lot of changes in the map... the fuel map especially. If you remember Bob had set the original fuel map as best he could... but with a 6mm hole in the manifold he did the best he could. Once i found the hole, and fixed it I DEPENDED on the self learning feature to "fix" the fuel map. Well... now she has a dedicated fuel map built on a steady state dyno to keep AFRs(between 12.5 and 13) in the peak range to make power, and protect the "fragile" OEM cast pistons from detonation. So, back to the car.... with my new found trust in her overall character... and to signify her change from temperamental toy  ... into reliable, dependable toy  She gets her first new set of wipers in over 5 years a set of Anco Aero Advantage..... Why?? ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](https://i.ytimg.com/vi/ELBb6ahlGao/0.jpg) Now that she runs well besides wipers working, I felt it is time to finish up the parking brake. oldeskewltoy Wrote:The emergency brake cables need a fabricated bracket on the driverside(thank you Jesse), and a zip tie around the axle hop line mount to secure the passenger side cable. Back almost a year ago when the GTS diff went in we had been successful in finding mounting points for the heavy cables... but the small bracket inside the trans tunnel used to support the front where they come together was about 1" too far forward to actually be useful... so today we (Jesse and I) removed the bracket from its original location, reversed its position - to make mounting in the new location easier... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/movedbrakecablesupportbracket_zps817f546e.jpg) Now that the cables are supported front and rear, I can finish up with the handle. Anyone have a spare GTS parking brake handle? Josh informs me the GTS has a different fulcrum shape for the cable to ride in... and MAY be required to use GTS calipers and cables... OR... I can figure a way to lengthen the single cable about 3/4" to fit. oldeskewltoy Wrote:OR... I can figure a way to lengthen the single cable about 3/4" to fit. ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/parkbrakeextended2panel_zpsd8f680bd.jpg) I should have kept the lengthening to 3/4", I did about 1 1/4"(length of threads) and although it now works, I have little room left for further adjustment... If/when that time occurs that it is out of adjustment, I'll cut off the bindings and place the two sections a bit tighter together... but for now... we have a working parking brake..... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/handbrakefitted_zps5310a07e.jpg) NOW... maybe I can think about carpeting, and the remainder of the interior.... ... and so now begins the beginning of the end of this build...   Dan - You can |  ....  OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 | |||
					05-02-2014, 01:08 AM
				 Post: #195 | |||
| Surreptitious.....
					A few updates.... 1) the addition of 1" spacers on the back... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/installedspacerview1_zpsdcaf24f1.jpg) ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/installedspacerview2_zps45f8b382.jpg) and with much thanks to BB... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/gopromounted_zps7035610e.jpg) A short ride around the block in Surreptitious - http://youtu.be/dc5dzcKzZsc Dan - You can |  ....  OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 | |||
					05-02-2014, 02:12 AM
				 Post: #196 | |||
| Surreptitious.....
					you are welcome, looking good - hope you managed to get the sticky stuff off the light again.  I used clearfoil with quite some success to make it easier to remove again.
				 AE86 ex-daily | |||
					05-02-2014, 02:39 AM
				 Post: #197 | |||
| Surreptitious..... (05-02-2014 02:12 AM)Bean Bandit Wrote: you are welcome, looking good - hope you managed to get the sticky stuff off the light again. I used clearfoil with quite some success to make it easier to remove again. no need... I took the plastic lid of the box.... cut it to the basic size... opened up holes.... ![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/mountfashioned_zps3d456858.jpg) and bought 4 slightly longer screws....  nice... tight... and easily reversible....  going to try and make a jig for it so I can mount it on a head and then take time lapse stuff as well... Dan - You can |  ....  OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 | |||
					05-02-2014, 09:08 AM
				 Post: #198 | |||
| Surreptitious.....
					Cool cam mount    FABRICA MI DIEM, PVNC! | |||
					05-05-2014, 08:25 PM
				 Post: #199 | |||
| Surreptitious.....
					A couple of short videos.... First video using my new mount... shot in 720/120 video is pretty good... just a short ride around the local neighborhood http://youtu.be/dc5dzcKzZsc This one I shot in VGA... video is poor... but the sound...  http://youtu.be/oC73j3m_Hf4 Dan - You can |  ....  OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 | |||
					05-05-2014, 08:34 PM
				 Post: #200 | |||
| Surreptitious.....
					indeed lovely sound   - I'd never go below 720p - you can lower the fps to 60 or even 30 depending on situation. 120 is realy just for slow mo effects. Mind you Youtube butchers the quality anyway - no matter how good the original footage is. AE86 ex-daily | |||
