Surreptitious.....
07-02-2012, 05:57 AM
Post: #171
Surreptitious.....
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-02-2012, 12:36 PM
Post: #172
Surreptitious.....
Since its hard to find concrete info on this.
If i have the front part of the w58 driveshaft and the backpart of the ae86 driveshaft will i also need to make the w58 part shorter like you had to do? |
07-02-2012, 03:37 PM
Post: #173
Surreptitious.....
ditn Wrote:Since its hard to find concrete info on this. That IS what I'm doing. In the photo showing the 2 driveshafts, you'll note the front halves are the same length. The full driveshaft is from my Corolla, the half long shaft, a mark II Supra. The overall length of the AZ6 requires the driveshaft to be shortened. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-08-2012, 09:20 AM
Post: #174
Surreptitious.....
My swap is done and testet. Its awesome
07-09-2012, 01:23 AM
Post: #175
Surreptitious.....
Jan Pedersen Wrote:My swap is done and testet. Its awesome SWEEEEET.... do tell... WHAT is awesome about it???? Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-09-2012, 09:05 AM
Post: #176
Surreptitious.....
Its nice and close without the gap from 3rd to 4th
Testdrive: http://s244.photobucket.com/albums/gg11/...V_0148.mp4 Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch
07-09-2012, 05:45 PM
Post: #177
Surreptitious.....
SWEEEEEET :wink:
08-09-2012, 06:23 AM
Post: #178
Surreptitious.....
Well.... all in, she now has about 35 miles on her with her new transmission, and I have only one complaint....
It is so nice to have a modern gearbox - smooth, and perfectly placed... @ least in my AE71 it is :wink:
08-09-2012, 01:59 PM
Post: #179
Surreptitious.....
04-21-2013, 12:37 AM
Post: #180
Surreptitious.....
WAAAAY too long with out an update
from another forum Wrote:So I've been wondering. How's the 6speed working out? Well... with the S series 3.58 final drive... in reality... I don't need any gears beyond the first 4 Sooooooo... its time to swap in a final drive more appropriate. Here is Richmond Racing's 3.9 T series diff...... (originally for Legends/Dwarf cars) fitted into a GT-S housing. ![]() The Richmond is assembled with zenki spider gears... so zenki axles are the call. The emergency brake cables need a fabricated bracket on the driverside(thank you Jesse), and a zip tie around the axle hop line mount to secure the passenger side cable. Now... along with the diff, I have to swap in a different brake proportioning valve, because instead of drum brakes... I'm now running rear discs. ![]() Doing some research All AE86 drum brake cars use valve 22040, while the GT-S uses valve 12040. I then look up my car, and low and behold, the valve is the same as a drum brake AE86 - 22040. So even though I have a different master cylinder, AND the proportioning valve is mounted slightly lower, the lines will not have to be customized to fit the GT-S valve! So I remove the drum brake valve, and swap in the GT-S valve. Then I go about bleeding the brakes. At this point brake bleeding can be a REAL pain... because there is no longer any fluid in the master OR the proportioning valve... so I go about palm bleeding. What is palm bleeding??? You fill the master most of the way, and you put your palm over the reservoir and work your hand like you would a toilet plunger.... This slowly pumps the fluid through the master, and the proportioning valve allowing me to circulate the fluid without having to pump the brake pedal, or use a power bleeder. More to come....... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/Shifterinmotion.gif)
![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/Diffswap2_zpsab924625.jpg)
![AEU86 AE86 - Surreptitious..... [Image: AEU86 AE86 - Surreptitious.....]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/Diffswap3_zps6adfc46f.jpg)
