Sump Guard dimensions
03-14-2012, 10:45 AM
Hello,
I want to make / buy a sumpguard for my AE86. Preference is for Alloy 5mm (or stainless steel 3mm) Anyone has one for sale? or Anyone can share the dimensions please? Do they connect to the original fixation points (M6 bolts only?? Thanks in advance. |
03-14-2012, 10:51 AM
I do believe Grp4 fabrication do one, they just joined the forum.
03-14-2012, 12:28 PM
I have made mine in one afternoon.
I do use original fixation points, but the design uses tension brackets mounts as a support in case something happens.
03-14-2012, 02:18 PM
| Sump Guard dimensions | |||
| Dry sump kit | harkes | 2 | 6,289 |
06-27-2016 10:57 PM Last Post: Bean |
| Quick question - Brake Pad Dimensions | Lt86 | 2 | 7,512 |
06-07-2015 12:08 AM Last Post: jondee86 |
| Dimensions clutch master cylinder | bozu | 2 | 8,677 |
04-16-2015 07:11 AM Last Post: bozu |
| Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 30,620 |
03-13-2014 11:45 AM Last Post: Rascal21 |
| Dry Sump | SwissAE86 | 4 | 8,137 |
12-05-2011 09:08 AM Last Post: jondee86 |
