Strange moment curve
07-30-2013, 08:30 AM
I bought this set of cams specified as 280 IN and EX but have later found that they are probably not Sad
I have had great difficulty finding any specs on these cams. What I have is:
200a158000h 258 gr exhaust - road
200e196000w 296 gr inlet - rally/race
07-30-2013, 09:55 AM
harkes Wrote:I bought this set of cams specified as 280 IN and EX but have later found that they are probably not Sad
Hi Niels
I have a set of schrick cams you can lend if you want too.
Specs for the camshafts:
200E1960-00:
opening duration: 296°
lift max.: 8,6mm
peak timing: 105°
lift at TDC:3,3mm
and
200A1960-00
lift max.: 8,6mm
peak timing: 105°
lift at TDC:3,3mm
Regards Lars ( They are located in Ikast)
http://s141.photobucket.com/albums/r69/larszylauv/
07-30-2013, 11:21 AM
the pulses in the engine are not working because off you cams set up
and remember that the "old" gr A cams are for big port head with STD peleaum chamber and carst iron exhaust manifold.
and maybe a bad porting off the head also
I will sugest a set off new cams
07-30-2013, 11:28 AM
and I forgot
the R1 is made for torque, not the best for this old RPM cams (inlet)
07-31-2013, 07:31 AM
rene Wrote:and I forgot
Hi Rene
You seem to know a bit about this R1 exhaust. Which cams would you recommend then? Any suggestions for the length of the inlet funnels?
07-31-2013, 10:26 AM
hi Lars
is it a racing engine ? or road
retainers, springs, STD or
followers ?
funnels you mean air horn ? I find the best length on the rolling road
where did you get the R1 from ? or the idea to use it ?
08-02-2013, 10:29 AM
This is the cams that is in det engine.
The text on them is: D1147 5036
[Image: AEU86 AE86 - Strange moment curve]
08-06-2013, 06:11 AM
Engine finished on the dyno... Result somewhat different than expected. These cams was bought 2. hand as ~280 - dont think they are... Huh
08-06-2013, 09:15 AM
That's making good torque high in the rpm range... I would be happy Smile
Cheers... jondee86
08-06-2013, 02:42 PM
I don't know what you have expected
but this are low lift cams with duration, then you get power in the high rpm range
and not a masive torque
  Strange ignition problem kpretro84 12 30,676 04-20-2013 02:34 AM
Last Post: jondee86
  strange sound from steering Ryo 9 16,875 04-21-2011 07:04 PM
Last Post: allencr
  Strange timing issue ? totta Crolla 11 17,139 06-18-2010 01:48 PM
Last Post: totta Crolla
  Halfshaft moving in & out - strange problem max_ae86 6 8,854 05-22-2010 10:16 PM
Last Post: max_ae86
  Strange TRD pistons 4a-ge Mikzu IV 12 34,592 03-19-2010 11:08 PM
Last Post: Jimmi The Kid
