Stock Bigport Engine + ITB?s?!
07-20-2012, 01:30 AM
Thanks jondee!
07-20-2012, 11:09 AM
After some reading...
Doing this is not the smartest move..... Better think of another one! |
07-20-2012, 05:44 PM
If you want something that run properly you definitly need a aftermarket ECU .
I will give you the same advise as I give to my friend Stephane: -Megasquirt DIYPNP + Tunerstudio (software) -a good AFR gauge (I personnaly love the Innovate MTX-L) -ITB (AE101, AE111, Jenvey, SK, etc...) + appropriate intake manifold / adapter. -some good velocity stacks -air filter socks (or better a good air box with a filter) -vaccum hoses + collector (mostly for the mastervac if you don't want to remove it) And that's it ! After few hours of road tuning: (he had never touched and ECU map before) |
07-20-2012, 11:18 PM
pack Wrote:After some reading... Yes... just because it can be done, doesn't mean that it is a good idea :wink: Cheers... jondee86 |
07-21-2012, 01:51 AM
Really thought it was easier....
And the big problem is not the parts, or ecu or everything else... It's all the money i will spend on something that with the same money i could do alot better! Like a blacktop itself... |
07-21-2012, 02:52 AM
DIYPNP: ~460€ (425$+40$ for shipping + tax)
AE101 ITB: you can find some for less than 200€ T3 adapter: ~270€ Vaccum collector: ~40€ hoses: few € Total cost: ~1000€ Velocity stacks and air filter socks <- you will need them too if you swap a 20v. So IF you can have a blacktop + a water relocation kit (T3 = 690$ + shipping ...) + a distributor relocation kit (the SP-TEC kit is 600€ + shipping from japan...) For less than 1000€, YES it doesn't worth to modify your 16v. If you look carefully at the pros and cons, I'm not sure a blacktop really worth it except if you can find a bargain with all the job already done ! By the way the swap isn't that simple, the wiring itself is a nightmare if you have to do it yourself... PS: MTX-L cost 180€ delivered and for me an AFR gauge it's a "must have" whatever engine you have. |
07-29-2012, 08:29 PM
Hi mates
I heard a few days ago that: with the stock 16v [u:17ccade8ac]MAP[/u:17ccade8ac] big port + 20v BT ITBs + Bigger injectors you can get +-15hp more, with standard ECU (MAP) ...is this true?? i always thought we need other ECU. ![]()
07-30-2012, 03:28 AM
If it ran at all, it would be running richer than Bill Gates !!!! If you
were lucky... REAL lucky... you might get it to make some power at >7000 rpm, but otherwise it would be a dog to drive Cheers... jondee86 |
07-30-2012, 07:48 AM
Project D Wrote:DIYPNP: ~460€ (425$+40$ for shipping + tax) you missed a few important things ![]() and as mentioned before, despite the fact that ITBs can be fitted to the engine they WILL reduce driveability (loss of torque below 4500rpm) without other mods. What I recommend to my friend is - ignore the bling factor of ITBs unless your pushing out at least 160hp and rather go for a nice header - a good one will give you something in return performance wise + street cred if in need. AE86 ex-daily |
07-30-2012, 09:18 AM
jondee86 Wrote:If it ran at all, it would be running richer than Bill Gates !!!! If you Thanks mate. What I imagined...too easy. ![]()
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,211 |
| 82mm Stock compression Pistons | apardal | 4 | 5,164 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 18,254 |
| Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 8,033 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,646 |
![AEU86 AE86 - Stock Bigport Engine + ITB?s?! [Image: AEU86 AE86 - Stock Bigport Engine + ITB?s?!]](https://st.forocoches.com/foro/images/smilies/r.gif)
