Steering shaft issue
11-15-2018, 07:42 PM
You can drill a small hole in the thick side of the bush and use a grub screw to hold the insert.
11-16-2018, 06:24 PM (This post was last modified: 11-16-2018 07:28 PM by Ryo.)
The idea is good but i doubt it will withstand the drilling those bushings seems fragile i already tested i tried to melt one broken in order to weld another as i have 3 shafts but none is complete the other two i dismantled few years back. Yes stupid i know that i figured now that this part should be not dismantled. Looking more on the bushing place on the shaft you can notice it its like U shaped i think if they factory sealed this two points they used liquid like silon. As the material was sticking outsie the holes on the main shaft where they a are bind together the holes are 2mm in diameter only.
85' AE86 GT coupe lifetime project since 2005
11-16-2018, 11:23 PM
When you assemble the hollow shaft and the solid shaft together,
does not the nylon ring stay in the groove even if it is broken ? If
the nylon ring stays in the groove (held/trapped in position between
the two shafts) then it should work just the same... hmm ?
Cheers... jondee86
11-17-2018, 01:22 PM (This post was last modified: 11-17-2018 01:23 PM by totta Crolla.)
(11-16-2018 11:23 PM)jondee86 Wrote: [ -> ]When you assemble the hollow shaft and the solid shaft together,
Cheers... jondee86
I guess the question is whether the bushes transfer any of the force between the 2 shafts and would you feel any slack in the column when driving ? I would say not, I would say the bushes are there to ensure the column could collapse even if it became corroded, something that you eluded to earlier. Wink
11-17-2018, 04:08 PM (This post was last modified: 11-17-2018 04:09 PM by Ryo.)
What about polyamide hot melt sticks i can use a glue gun and use the holes to fill it in so it will be like factory made. I am still not sure what type of sticks to use as there are many on market with different properties for the glue gun so they have the properties of original but i am sure they used the same holes and the very same application when they put it together i photoed in detail where you can see it. It was clearly not solid form before.
11-19-2018, 09:52 AM
That looks like it was cast in place to me indeed. In that case, try getting your hands on some ABS or Nylon 3dprinting filament.. takes a lot of heat (200+C) to get it flowing but with care you could probably get it to work..
  PWR light issue and no brake fluid after winter storage magpie 10 8,439 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 12,215 04-29-2022 05:45 AM
  Clutch Issue Deaty 8 8,428 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 5,333 03-14-2021 08:52 PM
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 11,374 07-31-2019 11:28 AM
