Spark Plugs : which ones to use 4age ?
07-26-2007, 12:36 AM
bought BCPR5EY NGK Spark Plugs
53.6 Tsukuba: http://www.youtube.com/watch?v=Kd-AnG3LYUg
try this one: http://www.youtube.com/watch?v=t1IiUAtoNBk
08-03-2007, 10:51 AM
I recently ordered a set of BKR6EIX for the smallport but forgot to mention that I need 0.8mm gap. They've sent me the BKR6EIX-11... Sad
What are the effects of using this with bigger gap? AFAIK the gap cannot be adjusted on the Iridium plugs.
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
08-03-2007, 03:02 PM
Which ones do I need for a silvertop turbo??? Banging head I put spare ones that I had in a 4g92 engine and the silvertop ate them in 2 weeks!!!
08-04-2007, 10:28 AM
@SutteR
The larger gap is unlikely to make any noticeable difference if your
ignition system is in good condition. AFAIK a wider gap can actually
improve charge firing, but it is a bit more difficult for the spark to jump
the gap. This can contribute to misfiring under high load, high rpm
operation... hardly an issue unless you are racing Smile
@Sgonzalez
Since there was no factory silvertop turbo, there are no plug listings.
Best bet is to use the OEM plug recommended for the base engine and
go one heat range colder. A turbo engine just runs hotter, so you need
a colder plug. Using a plug from another engine is not a wise choice, as
the plug design may be different, possibly leading to overheating of the
plug tip... and a short plug life.... Tongue
Cheers... jondee86
08-04-2007, 09:30 PM
jondee86 Wrote:@Sgonzalez
Cheers... jondee86
What about plugs for 4AGZE ?
08-04-2007, 11:50 PM
Typically a silvertop turbo has high compression and low boost, so one
heat range colder on the standard plug should be fine for normal
everyday use
. Maybe go two ranges colder on race day Smile
However, 4AGZE => 4AGTE conversions will typically run 15 psi or even
higher boost, so plug choice gets a bit more complicated. You can try
experimenting with other plugs until you find one that works for you. If
it can ignite the mixture reliably under all boost conditions, and the heat
range falls somewhere between fouling and vapourising the electrode,
then you are good to go Smile
Best to talk to people who are running similar setups, and have a read
of this link to get a few ideas :
http://www.lextreme.com/sparkplug.html
The silvertop head design is quite different from the 16V GZE design,
so you can't take it for granted that one will suit the other.
Cheers... jondee86
08-05-2007, 12:21 AM
THANKS JONDEE86 AND JAMIEMIRROR FOR YOUR ADVICE, THE CAR FUNS 11 PSI OF BOOST!!! AND YES., THE CAR HAS A PIROMETER AND IT GETS REALLY HOT INSIDE DE ENGINE
08-05-2007, 01:03 PM
You have EGT ? Do you have some data logged ?
08-05-2007, 10:34 PM
jondee86 Wrote:@SutteR
Thanks. Actually I use the engine for drifting so there might be some trouble for me using these?
08-06-2007, 02:00 AM
jamiemirror Wrote:You have EGT ? Do you have some data logged ?
It is an analog pyrometer!!
  20v BT - which oil pump? Mylesmck 4 5,681 06-21-2022 04:51 PM
Last Post: pack
  Weak spark, doesn’t start. AlexFourTwenty 4 18,765 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  Rim width. Which is best.... Dino86 5 9,544 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 10,942 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 7,010 02-15-2015 11:14 AM
Last Post: ditn
