Spark Plugs-Map Vacuum Pressure-S-AFCII Mapping Q's
03-01-2005, 02:34 PM
because of apexi hi and low throttle setting i would go to about 10% low and something about 70 to 80 at high throttle (or 20%low 90%high). difficult to explain this in englisch .... its mainly bacause you get a closer erea the apexi is interpolating in. but thats a point i would not worry to much about.
for tuning use a lambda meter. on a dyno it is best cause its easy to hold constant rpm. but if you have a mobile lambda meter you can do this with left foot breaking to keep constant speed (thats what i will have to do if we loose our connection to the dyno hey, what lambda is best for an NA engine roughly by the way? i would say around 0.9 on full stick. is this right? (i just worked on turbos til now...) a good tool i can recomend is a chassis ear http://jcsonlinetoolshed.com/product.php/3668/129/ this is good to detect pinging!!! just in case... |
| Messages In This Thread |
Spark Plugs-Map Vacuum Pressure-S-AFCII Mapping Q's - PazzaAE86 - 02-26-2005, 01:22 AM
[] - mo-racing - 03-01-2005 02:34 PM
| map sensor cheating? | fdsjakl890 | 8 | 3,981 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| AFM to Map Conversion | ps13michi | 3 | 6,393 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 18,706 |
| Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 26,472 |
| Weak spark, doesn’t start. | AlexFourTwenty | 4 | 18,890 |
