Spare wheel & spare wheel carrier
01-12-2026, 05:44 PM
Hi folks,
2 things - My 86 came no spare wheel, and no spare wheel carrier (Toyota part 5190012020 ).
Does anyone know what is the maximum size wheel you can fit in the spare wheel well ? i.e. 14" alloy with tyre ? and also ideally does anyone know of a suitable replacement for the spare wheel carrier bolt/nut setup ?
thanks
01-12-2026, 08:08 PM
Any full-size wheel will stick out of the well vertically, so if you want a flush spare, it needs to be some form of narrow emergency wheel.
I removed the spare long ago, but don't remember whether or not the bolt that held it in place was missing when I received the car or not. The spare was a single RS Watanabe 14x6 wheel.
01-12-2026, 10:22 PM
Suitable replacement: Flos has got you covered:
https://flos.ie/store/spare-wheel-bolt-a...13105b7e4e
01-12-2026, 10:45 PM
thanks Ivan - its out of stock for the lads, and no estimate on it returning, hence I was hoping someone might have an aftermarket solution ?
01-13-2026, 10:54 AM (This post was last modified: 01-13-2026 06:17 PM by banpei.)
I printed my own carrier:
[Image: AEU86 AE86 - Spare wheel & spare wheel carrier]
If I remember it correctly, I used a standard M8 rod and nut from the local hardware store and cut it to length. Total cost was something like 5 euros. It supports two different diameters for the center bore (60mm and 70mm), but lacks the diameter for the Almex (73mm). It's fine, and I never had an issue with the wheel shifting around. I can share the file with you if you like.
01-14-2026, 10:02 PM (This post was last modified: 01-14-2026 10:03 PM by jomme_mega.)
(01-12-2026 08:08 PM)decryphe Wrote:  Any full-size wheel will stick out of the well vertically, so if you want a flush spare, it needs to be some form of narrow emergency wheel.
if im sure stock 86[Image: AEU86 AE86 - Spare wheel & spare wheel carrier] wheels mostly seen on us models can fit nicely
(01-13-2026 10:54 AM)banpei Wrote:  I printed my own carrier:
niceBig Grin
peugeot 206 lover
i love the ae86 two
  lowering - adj. panhard rod & rca's & panhard bushin Apolan 8 9,212 05-24-2009 10:20 AM
Last Post: Apolan
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 16,115 03-12-2008 02:58 PM
Last Post: Roku_trueno
  Tokiko Hp & Eibach & Cusco 1.5 RS & koni Sport Abe 8 8,650 05-17-2006 04:30 PM
Last Post: Abe
