undoing the dashboard, need TIP
01-25-2005, 02:36 PM
The answer is apparently something easy and obvious,
but besides I 've allready spend some time unscrewing every bolt on the down half of my dashboard do to the turbo timer and hallmeter instalation, I havent managed to do the same with the upper half.
Plz check pics and help me:
[Image: AEU86 AE86 - undoing the dashboard, need TIP] http://www.jdmbits.com
01-25-2005, 02:54 PM
Okay..I've been there a few times. To get the part around the gaugecluster of there are 3 screws above the cluster (underside of overhanging bit of dash). You can pull off the light and wiper switches, underneath are some big nuts, take those off and you can pull off the part of the dash without any problems. I've only listed the bits that arent obvious, any other nuts and bolts in plain sight should also be taken off if they attach to the dash.
01-25-2005, 03:06 PM
thx i'll inform you soon
01-25-2005, 03:35 PM
Yeah sounds pretty much like what I did.
I had some problems with the steering wheel getting in the way when I took out my instrument cluster though...
01-25-2005, 03:50 PM
he wont have that problem with the smaller steering wheel he has.
Anyway, I managed to get it in without breaking anythin on senna's car, so it is possible.
  Digital speedometer on stock dashboard FanIsHere 0 2,800 11-09-2022 01:36 PM
Last Post: FanIsHere
  Tip! Oil funnel. krullibull 2 4,877 06-04-2013 12:59 AM
Last Post: fax0815
  Dashboard 1984 vs 1986 Dino86 3 5,548 11-08-2012 09:39 AM
Last Post: Dino86
  Stack dashboard in AE86? ZaX 2 6,622 01-27-2012 11:07 PM
Last Post: NoHachi
  Tip: replace shifter bush! danielvanderwoude 1 4,051 09-18-2009 12:14 PM
Last Post: danielvanderwoude
