Small question about wheels
07-18-2013, 11:46 PM
I know this is a AE86 forum, but i have a question about wheels:
I found some cool used rims with the sizes: 14​x6J-114.3.
Now, what if 'my car' (Toyota MR2 AW11 NA) has 4x100 bolt pattern instead of 4x114.3 which is stated above.
Does these rims fit 'my car'?
I have no experience with enginering cars, but what do you need to do so they can fit, or is it impossible??
The AE86 has 4x114 so that's no problem.
Oh, and i read something about adapters. Don't know what it is. Blush
-Vortrex
Quote:“The One With The Stronger Heart, Always Wins The Battle!!!”
Let's Go Out of Here..... Together.....
“1988 Toyota MR2 AW11, My Go-Kart AE86!”
07-19-2013, 08:00 AM
They won't fit.
They can be made to fit, but for 14x6 you would be mad to do so. There are TONS of nice 4x100s for sale in NL.
07-19-2013, 09:58 AM
These are adapters...
[Image: AEU86 AE86 - Small question about wheels]
http://prowheeladapters.com/4x100-to-4x4...apter.html
You just need to do some measuring to make sure that your wheels will
fit without the tyres rubbing if you use adapters (also known as bolt-on
wheel spacers). Check your local legislation to make sure they are legal
(if you care) before buying. Some countries require the spacers to be
hub-centric and stipulate the maximum thickness allowed.
You also need to check if there are recesses in the back of your wheels
between the bolt holes. If you use 25mm thick spacers and your existing
wheel studs are 30mm long, the extra has to have somewhere to go !!
Cheers... jondee86
07-19-2013, 12:29 PM
Okay, thanks for your answers!
*EDIT: actually, i was searching for wheels, for the future.
But i couldn't find lot of used watanabe's.
Do you know some good places to find those?
07-19-2013, 01:02 PM
Vortrex Wrote:Okay, thanks for your answers!
Auction Yahoo
http://auctions.yahoo.co.jp/ Thumbs up!
Then use a shopping service like Celga or something. Tho for wheels i think that shipping is gonna be pretty expensive.
Ebay UK
http://ebay.co.uk
Driftworks (Not Watanabe but alot cheaper and they're new and wider)
http://www.driftworks.com/rota-rbr-in-gu...-et10.html
http://www.driftworks.com/rota-rkr-15-wh...lours.html
07-19-2013, 01:43 PM
Check VW forum. 4x100 is a common size in europe.
  Early tvis red top from e9 gti small or bigport? Ryo 3 10,089 04-20-2018 09:14 AM
  Small Port Swap Alex170984 1 6,215 11-21-2016 01:46 PM
Last Post: Alex170984
  Small Port 10.3 Pistons Alex170984 1 6,176 10-25-2016 09:18 PM
Heart Question about AE86 Wheels CHACAMAN 5 13,817 09-10-2014 02:17 AM
Last Post: zenki
  small port engine totta Crolla 4 7,955 07-03-2010 10:05 PM
Last Post: totta Crolla
