Small port engine
04-24-2010, 08:35 PM
Small port engine
So I have a smallport head, bottom end, inlet manifold injectors, fuel rail, tps and ecu.
I know that I need to modify the plenum but can anyone please tell me what else I will need to make it run as a smallport.
I think it will be distributor and injector clips. can I however use the bigport injectors ?
04-24-2010, 09:48 PM
Small port engine
I'm guessing you might need a resistor pack, but I'm not sure.
Do a search for hi-z or lo-z injectors.
You might also need to swap pulleys over since the FWD waterpump is different to the RWD one. The RWD waterpump has a longer nose because of the bigger bearing they put in there to support the engine fan.
If you stick to a fwd pump then you need the fwd pulley, but I would advise against using the belt driven fan in that case.
04-25-2010, 12:24 AM
Small port engine
If you have the original bigport RWD, just strip everything you need
from the bigport and swap it onto the smallport. If you get an inlet
adapter plate, you can use the bigport manifold, injectors, harness and
ECU. Easy peasy, but you don't get the torque benefit from the smallport
inlet manifold design.
If you cut-n-shut the smallport manifold, you should use the smallport
injectors and ECU. Means a lot of rewiring, and you would need a FWD
smallport engine harness to butcher for the plugs. Smallport JDM injectors
are high impedence, so no resistors required.
Cheers... jondee86
04-25-2010, 12:40 AM
Small port engine
jondee86 Wrote:If you cut-n-shut the smallport manifold, you should use the smallport
Cheers... jondee86
+1. This is the best way.
http://86life.wordpress.com/
  4AGE Big port head failure Blaze0010 3 1,628 01-23-2026 03:35 PM
Last Post: totta Crolla
  Early tvis red top from e9 gti small or bigport? Ryo 3 10,036 04-20-2018 09:14 AM
  Small Port Swap Alex170984 1 6,179 11-21-2016 01:46 PM
Last Post: Alex170984
  Small Port 10.3 Pistons Alex170984 1 6,147 10-25-2016 09:18 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,207 10-30-2013 11:18 PM
