Shifting from 4th to 3rd
04-26-2017, 06:39 PM
Hey all,
Since my T50 TRD quickshift my shifter had problems from 4th to 3rd....
Back to the OEM shifter and the issue is still on....
I disassembled my gearbox entirely and everything looked OK.
What may be the problem with my shifter or gears?
It is only from 4th to 3rd, no scratch or noises...... It just "locks" then most of the times i have to go back to second and then to third again.....
Anyone to help me out?
Thanks
04-27-2017, 09:46 AM
I'm not sure a 100%, but I think the 3rd gear is the only one without bearing.
So maybe the output shaft or the bore of the gear itself is worn out to a point where the sleeve bind against the synchro ring.
Did you take pictures during the disassembly ?
04-27-2017, 10:23 AM
Nope.... I guess i'll have to disassemble the gearbox again.... Sad
Before disassembling the gearbox, it was just perfect.... Can't really find any reason for this...
04-27-2017, 01:14 PM
I have the same problem when going from 3rd into 2nd since removed/ installed my shifter... Not a big deal on my side as my gearbox is going to be changed for a J160 one but I'm also curious where the problem is.
Daily Beater: Civic EG5
Work in progress Car: AE86
04-27-2017, 01:18 PM
I also want to swap my Gearbox. Still... there's no development on the Irish guy doing those.....
So i'll be waiting a bit longer....
04-27-2017, 05:50 PM
(04-27-2017 01:18 PM)pack Wrote:  I also want to swap my Gearbox. Still... there's no development on the Irish guy doing those.....
SQ is soon done with his kit for the G-J160. The one for S-J160 is available but is getting a revision.
04-27-2017, 06:10 PM
SQ is probably getting done soon.... But there is no detail on the fitment. At least from my search....
04-27-2017, 07:26 PM
Worn selector fork or sleeve.
They no longer push straight but go slightly sideways and then lock out.
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 9,185 11-27-2015 10:06 AM
Last Post: Project D
  Whining noise only in 4th & 5th. izanagi 7 14,905 09-25-2014 07:09 PM
Last Post: Uzelac
  SR20DET (S13) gearbox shifting issues in AE86 heshan 8 14,975 07-22-2014 01:07 PM
Last Post: heshan
  3rd door support gas springs (stay) - worn out max_ae86 5 8,517 09-01-2013 03:20 PM
Last Post: Jezza_hr
  trans wont shift into 3rd or 4th :( odeaten 16 18,894 05-01-2008 01:12 AM
Last Post: F0Bman
