Seeking tech specs for AE86, can u help?
04-10-2007, 07:04 PM
I work for a game company and I am trying to track down the following stock technical specifications for the 1986 Toyota Corolla GTS AE86 USDM
I've hunted around the net and found lots of info on the AE86 in forums and FAQ's etc but I am missing this stuff
wheelbase
track width front
track width rear
length, width and height
tire sizes front and rear
gear ratios for reverse, final drive, 1 2 3 4 5
top speed, 0-60, 1/4 mile, lat-g
curb weight
If anyone can help me i'd be very grateful,
Cheers,
Gethin.
04-10-2007, 08:17 PM
here's a section from what wikipedia has to offer on the subject
Quote:GT-S specifications
* Horsepower: 112 hp (84 kW) @ 6600 rpm
* Torque: 97 ft·lbf (132 N·m) @ 4800 rpm
* Weight: approximately 2200 lb (998 kg) to 2400 lb (1089 kg)
* Engine: 4A-GEC, 1587 cc
* Engine Type: DOHC 16-valve Inline-4 Multiport Fuel Injection w/T-VIS
* Transmission: T50, 8-bolt flywheel
* Injector Size: approx. 180 cc, low impedance
* Compression: 9.4:1
* Differential: 6.7" Open (T282) or optional LSD (USA Only) (T283) with 4.30:1 Ratio, 2-pinion
* Wheels/Tires: 14x5.5" +27 mm Offset Rims with 185/60-14 Tires (195/60-14 for 86+ models)
1986 model year (August 1985 to July 1986)
* Corolla Sport receives its first major cosmetic update
* Power windows option added (GT-S Only)
* Interior cloth changed from tweed-type to velour type with checker pattern (GT-S Only)
* Door panels changed to cloth type from vinyl type (GT-S Only)
* Doors received separate arm rests that screw on instead of the moulded vinyl type (GT-S Only)
* Rear axles changed to a larger diameter (10/85+ models, GT-S Only)
* Updated clutch master cylinder design, to provide less squealing
* Automatic transmission shifter updated to a nicer look (SR5 Only)
* Seat design updated, back changed to a single pad, from a 3-pad setup, hard shell extended upwards (GT-S Only)
* Steering wheel updated from a square horn to a more rounded (6-sided) design (USA, GT-S Only)
* Tail lights updated, black plastic garnish added around license plate
* Spoiler removed (GT-S, 3-door Only)
* Black plastic trunk garnish added (GT-S, 2-door Only)
* Black plastic wheel opening trim added (GT-S Only)
* Optional alloy wheels changed to a spoked "Snowflake" design, only available in silver (GT-S Only)
* Optional alloy wheels changed to a 7-spoke design (SR5 Only)
* Vacuum pump added to cruise control system
* Vacuum switch added to cruise control system (04/86+ models)
* Headlight garnishes changed to a more curved, reflector design from a flat black design
* Front side markers changed to match front headlight garnishes
* Front grille enlarged to extend underneath front headlights, bumper extensions appropriately made smaller
* Third brake light added (CHSML) to comply with federal regulations
* Gauge cluster illumination changed from green to white
* Faint vertical lines added to gauge cluster background
* Gauge cluster needles changed to white, and design changed
* Smaller gauges changed to white needles, with different markings
* Headliner changed from vinyl type to a fuzzy cloth type
* Sun visors changed from all-vinyl to half vinyl/half fuzzy cloth type
* Sun visor shape changed to block more sun above the rear view mirror
* Climate control changed to an all-symbol design with a more textured feel to it
* A/C compressor manifold frame has larger ports
* Front/rear seat movement handle changed from inner section to outer section of front seats
* Cutout added on rear privacy cover for 3rd brake light (3-door Only)
* Switches on the dash (rear defog, rear wiper switch) now light up at night
* Clock on dash now has the lettering all black, instead of being offset in white
* Side decals made much smaller and are now only on the doors, not fenders or quarter panels (GT-S Only)
* "Diagnostic" terminal replaces two-pin short-out terminal to get information from vehicle components and put engine in diagnostic mode
* Horn moved from underneath headlight to hood latch support
* Trunk decals changed to a gradient design from the lined type (silver to black gradient)
* Gas tank receives baffling to prevent starving the fuel pump around corners when low on gas
* Steering rack changed slightly, slightly smaller, with larger bushings to compensate when mounting
* SR5 interior colours: black, blue, maroon
* GT-S interior colours: black, blue
* GT-S exterior colours: black, blue, light blue, red
http://en.wikipedia.org/wiki/Toyota_AE86
GEAR RATIOS for the manual 5 speed tranny (t50):
1st: 3.587
2nd: 2.022
3rd: 1.384
4th: 1.00
5th: 0.861
Reverse: 3.48
Final Drive is as mentioned 4:30:1
Wheelbase is 2400mm flat. I'll try to find other dimmensions to ina sec.
04-10-2007, 08:21 PM
Wheelbase
2400 mm / 94.5 in
Track
front
1355 mm / 53.3 in
rear
1345 mm / 53 in
Length 4180 mm / 164.6 in
Width 1625 mm / 64 in
Height 1335 mm / 52.6 in
Drag coefficient is 0.350 (if you need that to perhaps..)
04-10-2007, 08:30 PM
The 0-60 and quarter mile times vary from the amount of luxuries in the car; but comparing to (lighter) EUDM 124hp models and JDM 130 hp models which go 0-60 in anywhere from just under 8 to 9 secs. So i guess that would make USDM just under 9 to 10 maybe? i'd say 9 seconds. Quarter mile i'd guess from 16 to 17 seconds.. somebody please confirm.
Max lateral G-s would again depend on the amount of luxuries, type of rubber fitted and asphalt beeing driven on.. back in the days i'd guess 0.8 ish..
04-10-2007, 08:33 PM
Superb!
VERY much appreciated!
Also check in Homebrew Media section - some models.
04-10-2007, 09:15 PM
Apolan: can you sum that up in one post? Might be worth placing in the techref. Smile
[Image: AEU86 AE86 - Seeking tech specs for AE86, can u help?]
04-10-2007, 11:20 PM
EDIT: Okay i changed the apperance, im satisfied. Smile Hopefully this is good enough. I had some trouble deciding on the scope of the "article", but i decided to ommit things like injector size and impendance, and some other engine values and sizes..
Please do correct me if im wrong. There is alot of contradictory material on the internet, i did my best to make sense out of it. Im missing the swaybar thicknesses, thy slipped my mind atm, so if anyone has them...
Also teh performance figures are figurative Big Grin might vary greatly depending on thae actual engine type, condition, amount of luxuries etc.. but i think those stats can be achieved with a good sprinter.
cheers,saso
04-11-2007, 08:33 AM
Thanks! Thumbs up!
I've splitted it into the technical section:
http://www.aeu86.org/index/technical-ae8...topic=4815
Unfortunately you can't change anything now. If you want anything changed just pm me. Smile
04-11-2007, 09:48 AM
no problem. Smile hopefully somebody will pitch in with some data that i forgot; but i think the basics are covered.
  Can you name these Enkei wheels? midnightrider 1 4,068 01-11-2009 10:34 PM
Last Post: midnightrider
  hi everyone my name is tariq , you can call me tarook86 Dorikin86 4 5,813 12-31-2007 04:25 AM
Last Post: Sgonzalez
