Rust protecting your car
11-03-2004, 11:29 AM
I dont think using a microscope is a very realistic approach to remove rust. You need to get as much as possible of and neutralise the microscopic particles with some kind of rust converter if you want to stop it from rusting again after sanding. A better but also risky approach is to have the body panels sandblasted and painted in rustpreventing primer directly after that. Spraypaint wont do if I understand it correctly.
11-03-2004, 03:00 PM
I do not have ambitions to go over the entire body inch by inch with the microscope...... But on small areas with surface rust it is exelent Thumbs up!
02-02-2005, 01:15 AM
Mux, you where talking about glueing pieces of metal into your bodywork.
What kind of product you use for this.
BTW, thanks for the usefull information on rust treatment.
02-02-2005, 02:53 AM
Herman,
We ended up welding it afterall, not sure what the reason was.
I'll ask Martijn next time I speak to him what they use when they glue stuff together..
02-02-2005, 02:46 PM
My first car was Vauxall Cresta '59 (an GM car from England). I started to restore that car. When I stripped all old paint, I see that there were some older repair jobs. Instead of using polyester putty they used massive "welding" and filling with tin! And I swear - no rust around, no cracks, when the paint was on it - I cannot see any imperfections.
02-02-2005, 05:53 PM
robokill Wrote:Rust Sad
Every hachi has to suffer on it Confused
not mine... HAHHAHAHAHHAHHAAHHAHA I win Hurray! Hurray! Evil Evil Evil Evil
  Can you convert your 86 back too the original state? gh0st 7 6,784 04-25-2022 04:25 PM
Last Post: gh0st
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 26,907 08-19-2018 12:08 PM
Last Post: AlexKTM
  How would/have you rebuild your 4age? joaotcgt 6 12,368 07-21-2015 10:40 AM
  Rust in trunk AnthonyStallone 11 19,703 02-18-2015 06:23 PM
  Your Attention, Please.... oldeskewltoy 1 5,291 07-30-2014 09:04 PM
Last Post: driftmaniacae86
