Rubbing problem
09-01-2006, 05:23 PM
Rubbing problem
I just bought konig rewinds 14x7 -9 offset as you all know. But now I got rubbing problem on my front wheels, I got 185/60/14 size tyres. So sometime when I brake a bit too hard I will feels and hear that the tyre touch the fender or actually touched the bolts that fit the plastic cover. If the bolts are take off then I am sure it will touch the fender. If someone here know how should I solve the problem?
INFO: Tyres: 185/60/14 Rims: Konig Rewinds 14x7 -9 offset Springs:: Intrax (I think its lowered 2 or 4 cm I am not sure) Shock: Original OEM Car used: Daily driver, not for track Thanks in advance. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
09-01-2006, 05:32 PM
Rubbing problem
got the same problems sometimes when i want to turn into a parking place while braking a little
09-01-2006, 06:12 PM
Rubbing problem
Some gentle massaging with a BFH?
09-01-2006, 07:12 PM
Rubbing problem
BFH?
09-02-2006, 08:17 PM
Rubbing problem
BFH = big f**ing hammer i think
09-02-2006, 09:42 PM
Rubbing problem
i have the same problems with my 14x8 supra rims. the best way to fic this problem is to roll the fender. this is hard to explain. the inner part of the fender were it folds under get bent out and is then smoothed out to make it look better. here is some pictures http://www.aeu86.org/viewtopic.php?t=331...ed+fenders
i hope this helps matt |
09-02-2006, 10:37 PM
Rubbing problem
@oli: is that what the nohachi mean, TAHN! (Thanks and HELL NO!)
![]() @matto: yes I know what u mean. I will not roll my fender. I rather sell my rewinds than roll my fender LOL j/kAnyway I removed 2 bolts that hold the plastic cover and drove the car today and its seems the tyres does not rubbed anymore 1985 AE86 (ハチロク) Levin - Summer time daily driver |
09-02-2006, 10:40 PM
Rubbing problem
yeah i dont want to either. i have to see what i can do with the bolts.
09-03-2006, 04:23 AM
Rubbing problem
oli Wrote:BFH = big f**ing hammer i think :mrgreen: I have the same problem whit my konig -9 offset and 195/60/14..... I think take out Plastics.. and a bit of hammer and they work fine. Regards
| 4agZe problem solved - 99% IC problem | Okami | 41 | 48,976 |
| AC problem? Idle problem? | KD2229 | 3 | 6,485 |
08-19-2009 02:08 AM Last Post: KD2229 |
| Help! tire rubbing problem | DJexor | 6 | 8,194 |
09-14-2007 07:29 AM Last Post: Rick |
