Rolling road update
01-05-2008, 01:29 AM
Rolling road update
Rossi Wrote:Cams around the 270-280 area with 8-9mm lift are what i used to run and keep the power low down. Combined wth some headwork which is easy to see where you can improve even with a dremel. i.e matching inlet manifold ports to head ports and gaskets.
Should set you back no more than £500, i sold a pair of HKS cams for £200.
Can you tell me the likely power output of this + higher compression as above ?
01-05-2008, 01:27 PM
Rolling road update
Depending on the condition of your base engine probably around the 150hp mark combined with a good exhaust system and induction kit.
01-05-2008, 02:03 PM
Rolling road update
The guy that did the rolling road thought the engine was making about 136hp at the flywheel and suggested it was not bad for a standard engine.
He only did a power run, no adjustments were made and I know his rollers are pretty accurate.
The thing I'm weighing up of course is the difference between a mildly tuned 16v and a standard 20v
Some people suggest the 20v makes a consistent 136hp at the wheels http://66.249.93.104/search?q=cache:WHCV...ring&hl=en (paragraph headed 4age models)
While others say 145-150 at the flywheel
http://www.billzilla.org/4agmods.htm#115hp (about 3/4 way down page headed 4age 20v engines)
Can anyone shed any light on this, has anyone ever put a standard 20v on a dyno ?
  Sparco chrono road seat rails stratosTRD 6 10,282 09-03-2011 07:32 PM
Last Post: stratosTRD
  4AGE ITB's Rolling Road session byd1380 14 22,479 01-19-2008 04:13 PM
Last Post: ghostgrunt
  Rolling fenders??? ts@n@k@s 7 12,925 06-27-2007 05:26 PM
Last Post: momo-gt
  Discussion: blacktop 20v: the road beyond 200HP 86er 19 31,721 02-21-2007 07:06 AM
Last Post: BenR
  Discussion: blacktop 20v: the road beyond 200HP 86er 1 8,144 01-17-2007 06:25 PM
Last Post: 86er
