11-17-2009, 08:03 PM
Post: #231
you've even copied the tyres Big Grin
keep up the good work Thumbs up!
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
11-18-2009, 09:02 PM
Post: #232
Today I recieved the solution to my OBX exhaust problem
11-18-2009, 09:08 PM
Post: #233
looking good although I personaly prefer the spring type solution for better airflow and less turbulences, like this
but as you had to get a new piece in there certainly not a bad choice Smile
11-23-2009, 12:10 AM
Post: #234
Well got my OBX exhaust completly installed now.
And Ivan came to help me the whole Saturday. To bad we didn't got the car running due to a couple of downsides.
- empty battery
- mysterious electronic problem
- grounding problem
So on Sunday I went out for another try. This time Aram was so friendly to come along.
11-23-2009, 12:14 AM
Post: #235
now the problem.
Engine does crank and fuel pump is running but I am missing the engine check light during ignition key on first spot.
Seems there is no connection between the ecu and the rest of the engine.
I made a movie from it.
Hope someone can help me. Becaus I am running out of ideas why its not working.[/video]
11-23-2009, 12:33 AM
Post: #236
the sound in the ed after you turn the key again sounds just like when i had a shortcut in the light switch - probably not much of a help but it's defo the same sound (was apparent when the pin for the cluster had juice on without the lights themself)
I see you attached an additional ground - is the original ground that goes on to the intake plenum (thick wire where the injectors are) also attached?
11-23-2009, 08:55 AM
Post: #237
We had the plenum ground connected on saturday, looks like robo moved it to the chassis.. didnt fix the problem.
11-23-2009, 10:24 AM
Post: #238
Maybe You changed battery terminals? Check it.
11-23-2009, 11:47 AM
Post: #239
Thank you for your suggestion, but that I'm 100% certain we did that right.
11-23-2009, 12:16 PM
Post: #240
due to the busing sound at the end I guess some wireing got shorted or similar... I don't have a garage anymore to test things out as I just moved to Brussel but have a look with a current tester in the area of the drivers footwell... maybe you can locate the bussing sound and go from there
I'm not 100% sure but the sound seems to be for shortcircuited relay and switches in general... not just the light.
EDIT: don't guess you have the day off on a Monday or Wednesday? I could come and have a look...
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 20,900 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 204,136 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 897,515 09-03-2017 09:24 PM
  8a9 blue gt coupe McGlinchey 8 12,908 06-22-2016 02:19 PM
Last Post: McGlinchey
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 51,370 04-07-2016 12:15 PM
