RoCo Performance AE86 V8
02-22-2009, 11:15 AM
Post: #81
lol adam that was ALMOST constructive man.....
keep up the therapy its going grouse man ![]() clutch kick, switch, tree .... oowwww |
02-22-2009, 03:18 PM
Post: #82
improvedae86 Wrote:I was just sent this link Since I am in process of doing similar thing on the rear end of my ae86 I was analyzing lot's of RoCo's pictures on the internet forums. I have already pointed out the problem of roll center he will have on the driftworks forum, so it's up to him what to doo. http://www.driftworks.com/forum/drift-ca...post938005 I have learned my lesson here so I did it, I think better, but let's leave it to my topic, as I already jumped in here once. Drifting - best fun you can have in your car with your pants on! |
03-03-2009, 03:03 AM
Post: #83
since starting this project I have completely changed the car several times.
Was going to just run the v8. then I decided on a English s13 axle with welder, then I decide, on s13 front end, and s13 brakes, then I decided on s13 coilovers and turreted the rear end, then I decided to scrap the safety devices cage and do it properly, …. And even now im still chaging my mind. its taking ages, but a wise man ones said theres no short cuts in doing something right. im not going to spare any expense on this as its at such a stage it would ruin the rest of the car.im even going as far as replacing and painting each nut and bolt. I would still do somethings diffrent like axle placement, but I wana see how this set up works first. I can rectify things as I go as im unsure of what its going to be like as this setup hasn’t been done before all in one car. Hopefull it will turn out like the picture in my head, lol ![]() |
03-03-2009, 03:04 AM
Post: #84
next is the cage, thanks to wayne from swrc.
for bending the tube with his new benders, top guy. Main hoop, front legs ![]() rear x brace ![]() ![]() DASH BAR ![]() ![]() ![]() |
03-03-2009, 03:05 AM
Post: #85
Triangulating the front end out to the turrets.
![]() ![]() ![]() started on the door bars, and triangulated rear end ![]() ![]() ![]() ![]() |
Post: #86
x cross braced the door bars.
![]() ![]() ![]() started on the passenger door bar. ![]() ![]() ![]() ![]() ![]() |
03-03-2009, 03:06 AM
Post: #87
rear triangulation bars.
![]() ![]() ![]() ![]() rear harness bar ![]() ![]() |
Post: #88
started to mount the steering rack and pedal box
off the dash bar, I decided to put the box over the rack, and not on the floor. Less room but will look a lot tidier. ![]() ![]() ![]() ![]() |
03-03-2009, 03:07 AM
Post: #89
primed the full shell with anti rust/chip zinc primer
Post: #90
Welded in and ground the door bars flush, took ages to
Do right, but im happy with the outcome, looks sweet. ![]() ![]() ![]() |
A.D.D Performance AE86 RESTORATION NEARLY COMPLETE | cab32 | 24 | 33,665 |
08-08-2013 09:27 AM Last Post: Martynas |
roco's ae86 f20c | roco | 15 | 24,644 |
09-06-2008 07:46 PM Last Post: Ivan141 |
A.D.D Performance Demo car (AE86 project) | cab32 | 15 | 20,372 |
03-24-2008 03:34 PM Last Post: cab32 |
New high performance air filter | amigaguy | 11 | 14,522 |
06-07-2007 09:39 PM Last Post: amigaguy |
performance vs practicality | JamesAE86 | 14 | 16,403 |
10-14-2005 08:55 PM Last Post: Ivan141 |
