Ring & pinion ratio.
06-25-2014, 05:20 PM
(This post was last modified: 06-25-2014 05:22 PM by Bean.)
(06-25-2014 11:53 AM)AJPS Wrote: what sort of top speed to you hit at spa in an ae86? top speed (~195km/h GPS) on the straight, way before you get to the end. AE86 ex-daily |
06-25-2014, 06:19 PM
| Ring & pinion ratio. | |||
06-25-2014, 09:52 PM
Tomorrow I will check the ring by following the FSM steps.
This is the only thing that I've forgot to check when I assembled the new bearings. |
06-29-2014, 09:08 PM
(This post was last modified: 06-29-2014 09:09 PM by izanagi.)
What should I choose for daily drive and drift ?
Is 4.7 not suitable for daily ? I'm lost in my choice. |
06-29-2014, 10:19 PM
(06-29-2014 09:08 PM)izanagi Wrote: What should I choose for daily drive and drift ?As said cruising at high speed (i.e. motorway) will be annoying due to high rpm. Do you drive on the motorway or at higher speed in your daily routine? AE86 ex-daily |
06-29-2014, 10:44 PM
Yes but i'm also starting drift.
06-29-2014, 11:41 PM
The ability to drift your car is primarily governed by the amount
of power you have, and the amount of grip. Having a Limited Slip Differential is a big help The only benefit from using a 4.7 instead of a 4.3 is that you "close up" the gap between gears, and effectively make each gear a little lower. First gear with a 4.3 is already very low. Making it even lower will more or less make it useless, as you will easily be able to start off in second gear. And, while I am not a drifter, I would guess that unless you are doing donuts around cones, you are not going to use first gear much at all. So, I say use the 4.3 and get yourself a set of wheels with some skinny tires, pump them up to 45psi and go drifting Then put your good wheels and tires on for driving to work. Cheers... jondee86 |
07-05-2014, 07:35 PM
Get 4.7's if you drift and live with either going slower on the motorway or dealing with higher rpms/noise. IMO.
Andrew |
| ring gear bolts | DJexor | 3 | 8,097 |
12-26-2016 10:56 PM Last Post: totta Crolla |
| DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 24,150 |
| Checking ring gear diff | izanagi | 3 | 6,951 |
07-09-2014 07:38 AM Last Post: jondee86 |
| axle swap time how capable is a std crownwheel and pinion | fax0815 | 32 | 59,118 |
09-26-2013 08:33 PM Last Post: Lajoosh |
| Gear end , drive pinion height | filh | 5 | 14,561 |
06-27-2013 12:29 AM Last Post: filh |
