Ring & pinion ratio.
06-23-2014, 01:32 PM
Hi all.
What would be the best ratio for daily use and sometimes drift and track ?
Thanks
06-23-2014, 03:14 PM
(06-23-2014 01:32 PM)izanagi Wrote:  Hi all.
Thanks
depends on the track and what you understand under daily use. most use stock or 4.7 in my case a 4.7 is out of the question as long trips on the motorway are already annoying with the 4.3 due to the high revs.
Sent from my Nexus 4 using Tapatalk
06-23-2014, 03:43 PM
Ok. I think i will buy 4.7. My diff is still whining after changed my bearings so i guess it comes from my ring and pinion.
Any advice about a good brand not too expensive ?
06-23-2014, 05:43 PM
http://www.weirperformance.com/finaldrivegears.html
06-23-2014, 10:11 PM
no no i think its too sort 4.77 for daily use i use in my corolla 4.3 for daily its perfect
06-23-2014, 11:48 PM
(06-23-2014 10:11 PM)driftmaniacae86 Wrote:  no no i think its too sort 4.77 for daily use i use in my corolla 4.3 for daily its perfect
Ok thanks for your help.
06-24-2014, 01:56 AM
(06-23-2014 03:43 PM)izanagi Wrote:  My diff is still whining after changed my bearings so i guess it comes from my ring and pinion.
The crownwheel and pinion are installed as a set, and create a wear
pattern (contact patch) on each other after many years and thousands
of kilometres. Once the differential has been dismantled for repair, it can
be difficult to get the contact patch exactly matched. That is the usual
cause of whining. Same thing applies if you only install a new or used
pinion to an existing crownwheel.
Worn or loose (lack of preload) pinion bearings can cause whining, and
even just a worn out crownwheel and pinion. If the gears appear to be
in good condition, you could try adjusting the contact patch, or just put
up with the noise, and hope that it settles after a while.
Cheers... jondee86
06-24-2014, 08:53 AM
Cheers... jondee86
What do you mean by that:
up with the noise, and hope that it settles after a while. ?????
I should set up the ring much closer of the pinion ? With the same method showed in the factory service manual ?
06-24-2014, 01:16 PM
4.3 is ideal for daily, you will have good acceleration and top speed, with highway drivability.
For higher powered AE86 4.1 is even better.
With 4.778 anything above 100 km/h will be annoying.
06-24-2014, 06:50 PM
(06-24-2014 01:16 PM)Uzelac Wrote:  With 4.778 anything above 100 km/h will be annoying.
unless you are in a race
http://www.ajps.com.au
all things ae86
  ring gear bolts DJexor 3 8,059 12-26-2016 10:56 PM
Last Post: totta Crolla
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 24,101 12-21-2016 10:28 PM
Last Post: ditn
  Checking ring gear diff izanagi 3 6,906 07-09-2014 07:38 AM
Last Post: jondee86
  axle swap time how capable is a std crownwheel and pinion fax0815 32 58,742 09-26-2013 08:33 PM
Last Post: Lajoosh
  Gear end , drive pinion height filh 5 14,501 06-27-2013 12:29 AM
Last Post: filh
