Replacing of the bushings
11-22-2004, 01:17 AM
Guys, i'm still waiting for report of instaling the group buy bushings.
Not that much about the impresions of handling, because i know it will be a big improvement, but on how did you change the bushings. Especially on rear four trailing arms. I have a big problem with removing stuck bolt inside the bushing. ![]() ![]() I tried lot's of aproaches, but non of them worked except the angle grinder + cuting the bolt head. Please post some of your ideas. Drifting - best fun you can have in your car with your pants on! |
11-22-2004, 01:24 AM
2m metal tube
11-22-2004, 01:30 AM
Aico Wrote:2m metal tube um, not working, since bolt is rotating inside the trailing arm housing. whole bushing is rotating when you unscrew the bolt, but there is no force apllying on the bolt, so you are not pushing it out. We tried today to weld the nut on the other side of the rear side of the bolt, but the weld broke of, but bolt did not go out. Drifting - best fun you can have in your car with your pants on! |
11-22-2004, 01:44 AM
just warm it with a heatgun ???
I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
11-22-2004, 11:06 AM
i had to use the flex (grinder) too
11-22-2004, 11:33 AM
@Zax,
Everthing on my car did come lose very easy, gues I was extreem lucky if you consider the age of the car. Maybe the flexgrinder is a option, than you only have put on a new bold and nut. Michel Daily driver: Seat Leon Cupra V6 Summercar: E30 M3 Cecotto Projectcar: AE86 |
11-22-2004, 11:37 AM
When I took my spare axle appart it had all the arms attached (although the long ones where cut off half way). I got all the bolts out just fine except one. It has rusted to the metal insert inside the bushing so there is no way to get that loose except for cutting that bolt which I will do next time I have some time..
I hope I will be more lucky when I replace the axles... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
11-22-2004, 01:35 PM
Most of the bolts on the hachi haven't been removed in 20 years most if it just has to be heatet up then it will release.
by the way zax you hachi looks good from below Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-22-2004, 01:43 PM
robokill Wrote:by the way zax you hachi looks good from below I noticed that as well, how the hell did you get it to look that clean? |
11-22-2004, 02:24 PM
peter møller Wrote:He took out the silver spray can and went nuts!robokill Wrote:by the way zax you hachi looks good from below ![]() I want my hachi to look as clean too!
| Replacing Top Windscreen Moulding | chrisae86 | 2 | 3,149 |
06-18-2022 08:56 PM Last Post: chrisae86 |
| Replacing front lca | zenki | 6 | 7,164 |
05-02-2017 03:23 PM Last Post: pack |
| Poly vs OEM bushings | Jezza_hr | 5 | 8,900 |
05-14-2014 11:28 PM Last Post: Jezza_hr |
| Replacing brake servo/booster | Eifelaner | 6 | 8,056 |
08-17-2013 11:19 PM Last Post: Eifelaner |
| Replacing window wipers | bozu | 6 | 8,633 |
04-11-2012 03:15 PM Last Post: zenki |
![AEU86 AE86 - Replacing of the bushings [Image: AEU86 AE86 - Replacing of the bushings]](http://www.hr-a.com/forum/images/public/img-1079534803.jpg)
![AEU86 AE86 - Replacing of the bushings [Image: AEU86 AE86 - Replacing of the bushings]](http://www.trdparts.jp/image/bush_ae86s.jpg)
