Replacing brake servo/booster
08-16-2013, 01:15 PM
Im trying to replace my brakeservo,
i did what the book told me, but im stuck as you can see
[Image: AEU86 AE86 - Replacing brake servo/booster]
have i missed something? to me it looks like i have to take the intake manifold of :S
i hope someone can give me a hint
thanks
eric
08-16-2013, 06:11 PM
I'd sure try to jack/lift the engine up or pry it over before removing then manifold.
The mounts should give/stretch a cm or 2 if they're not broken and they should easily take 1cm without breaking, 2 is chancing it.
08-16-2013, 10:46 PM
From memory I think you can unscrew the fork part that connects to the brake pedal and doing this will make enough room to remove the servo.
08-17-2013, 01:30 AM
i allready took of the fork thingy, the rod is still to long, thats ehy im stuck
08-17-2013, 02:17 PM
was a while ago...
maybe try to push the rod in ?
08-17-2013, 11:19 PM
i'll try that when i have a friend over to help me
  Brake booster braket Mylesmck 0 2,557 05-19-2023 12:56 PM
Last Post: Mylesmck
  Replacing Top Windscreen Moulding chrisae86 2 4,286 06-18-2022 08:56 PM
Last Post: chrisae86
  Replacing front lca zenki 6 9,173 05-02-2017 03:23 PM
Last Post: pack
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 6,282 03-22-2016 09:43 PM
Last Post: ditn
  AE92 brake booster and master cylinder into AE86 bel_air 8 15,718 08-02-2012 10:51 AM
Last Post: bel_air
