Red panda coupe...rebuilded
10-16-2005, 09:26 PM
vladx_kc Wrote:yes, only the body is damaged. I'm collecting parts at the moment. but, I'm just a student so, it will be a little difficult.
cheers!
Hmmm, did you ask ZaX? He did use to have a lot of parts and perhaps he has still the ones you need? Dumb question
[Image: AEU86 AE86 - Red panda coupe...rebuilded]
10-17-2005, 06:02 PM
Welcome! Wave The damage doesn't look that bad, you could leave it as-is and tell everyone that's japanese Boro-Hachi style Smile I agree with you tough, things like that should be corrected as fast as possible.
The steering wheel you have is the one that's used in at least some Toyota cars. A friend of mine has an RJ70 LandCruiser with an identical one, and his seems to be in even worse shape. This material sucks! Do you have little buttons on the rear of it too? I think it should be possible to find a used replacement in decent condition.
I've recently seen a video from a Mobikrog drift day - the track is nice, but then again, the space between asphalt and guardrails is way too small. Too bad your car got dented because of this Sad Good luck with it!
10-18-2005, 07:26 AM
Just find a used mr2 steering wheel...that ugly brown thing never belonged in any ae86 as far as I know.
10-18-2005, 08:01 PM
Darkstar Wrote:I've recently seen a video from a Mobikrog drift day - the track is nice, but then again, the space between asphalt and guardrails is way too small.
the track could have been better, but its the only one we have and its reasonably cheap. it wasnt even supposed ti be a track (ex-military airport). so all you get is 90-deg turns w/ a few bends..
02-26-2006, 04:08 PM
After quite long time I saved some money, and my car is finaly at my friends garage. there is no rust under the fender, thanks god
Hurray!
Vladimir
N/A for life...
02-26-2006, 04:14 PM
and what do you think about that?
very rare example, webber 45, I think it would fit nicely on my 4AGE
Vladimir
N/A for life...
02-26-2006, 04:31 PM
do you have 2 of them?
I think TE71corolla and P-Nut from holland also just put a pair of 45 webers on a 20v 4age, so they'll work fine on a 16v too.
Jamiemirror might be able to supply you with a manifold for them. He's in your neighbourhood (well...around the balkan area).
02-26-2006, 11:34 PM
Manifolds are for 40s only (they can be adapted even via porting to 45s and here one friend use this manifold with Weber 45s, but they are not designed exacty for 45s).
02-27-2006, 09:47 AM
Well, it's probaby still easier and cheaper than buying these manifolds elsewhere.
03-04-2006, 07:21 PM
some progress is made. Thumbs up!
Vladimir
N/A for life...
  Banpei's two door panda Trueno from Japan banpei 194 52,839 Yesterday 12:54 PM
  Ivan's coupe: seeing RED Ivan141 684 1,253,806 Yesterday 12:02 PM
Last Post: cannabolic
  Gtsi-R red'n black coupĂ© Gtsi-R 147 177,807 02-03-2022 02:43 PM
  My panda ae86 build Ellzbmx 10 22,548 06-03-2015 10:56 AM
Last Post: Ellzbmx
  Red over Black UK Ae86 RobH69 5 20,100 02-03-2011 02:01 PM
