Rebuilding steering rack, which parts to renew?
10-18-2008, 05:05 PM
Has anybody any experience with rebuilding a steering rack?
I want to build in the QSR this week, so if anyone has any info, or better yet, a pictorial on this matter that would be great. Thumbs up!
Mainly I'm looking for the parts I can better renew while I'm at it, rings, gaskets etc.
Thanks,
Aram.
10-18-2008, 05:10 PM
I found this topic which is very handy. Thumbs up!
http://www.aeu86.org/viewtopic/quaife-qs...nfo/t/5985
10-22-2008, 05:40 AM
There's only a 'handful' of renewable parts.
2x bearings on the pinion gear
1x pinion shaft seal
1x rack shaft end bushing
2x tie rod end boots.
with new molybdenium grease and its good to go.
Andrew
10-22-2008, 06:02 PM
assassin10000 Wrote:There's only a 'handful' of renewable parts.
Andrew
I found these partnumbers, the bold ones are specificly for the AW11 rack, which I have, the other ones are for both.
My technical english is not good enough to recognize every item you listed above, but I will try to connect them.
I will make them red, can you confirm if this is ok?
45046-29135 Outer Tie Rod End (x2 LH and RH are the same)
45503-19066 Inner Tie Rod End (x2 LH and RH are the same)
45536-12011 Steering Rack Boot (RH 12/84-1/88, LH 12/84-12/89)
45536-17010 RH Steering Rack Boot (1/88-12/89)
90467-18003 Steering Rack Boot Clip (x2)
90461-10273 LH Steering Rack Boot Clamp
90949-01453 RH Steering Rack Boot Clamp
90363-13001 Pinion Gear Lower Bearing (12/84-9/89)
90363-13004 Pinion Gear Lower Bearing (9/89-12/89)
90363-15003 Pinion Gear Upper Bearing (12/84-9/89)
90363-15015 Pinion Gear Upper Bearing (8/89/12/89)
90311-15002 Pinion Gear Oil Seal
44277-17010 Rack Guide Seat
I also have heard something about spacers, to lenghten the rack a bit.
But I think this is for more steering angle, I found something called the battleversion 2?
[Image: AEU86 AE86 - Rebuilding steering rack, w... to renew?]
The rack will work without this and have the normal steering angle?
Hope you can let me know. Thumbs up!
Thanks
Aram
10-22-2008, 07:02 PM
Yep, those spacers are just for extra steering angle. I believe they are only put on one side of the rack, the picture above just shows the 2 styles of spacers that are commonly used (and in this case manufactured by battleversion).
10-22-2008, 10:50 PM
Ok, then for now I just need the correct part numbers. Smile
Only problem is that the driftday is coming Sunday, so I doubt I will have the rack ready before then. Confused
10-23-2008, 07:18 AM
Aram Wrote:I found these partnumbers, the bold ones are specificly for the AW11 rack, which I have, the other ones are for both.
IF these are for an AW11 you do NOT want them for a AE86. Use AE86 inner & outer tie rod ends on the AW11 rack - for swapping into an AE86. That would also include using AE86 steering rack boots.
These sound like what you need... But I think your missing the 'end' bushing for the passenger side of the rack.
A quick check on toyodiy.com and this 'might' be the p# you need for the bushing.
BUSH, STEERING RACK 45522-17010
Andrew
  20v BT - which oil pump? Mylesmck 4 5,191 06-21-2022 04:51 PM
Last Post: pack
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 9,945 07-31-2019 11:28 AM
  Quaife quick rack totta Crolla 19 26,772 03-03-2018 03:32 PM
Last Post: Deuce Cam
  Rim width. Which is best.... Dino86 5 9,065 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 10,461 07-27-2015 11:24 AM
Last Post: pack
