Rear link bushes
02-03-2008, 11:02 PM
Rear link bushes
I have removed the 4 link arms and Im about to fit uprated bushes.
The car is used for competition, tarmac rally, would it be better with spherical (heim ?) joints as opposed to rubber ? I'm thinking that the spherical joints will allow the axle to articulate more and faster, the rubber bushings seem to restrict movement. What would you do ? An analogue brain in a digital World |
02-04-2008, 12:07 AM
Rear link bushes
Polybushes are very,very good,
but so are heims, If you go down the rosejointing route, the shell had better be good at the axle points & should be given a bit of seam welding to strenghten, these joints also need to be replaced on a regular basis esp with bumpy rallying. Id polybush it, but then again I dont rally,,, My mates have used both, polybushing is just the easier of the 2 An 86 is for Life, not just for Christmas |
02-04-2008, 12:32 PM
Rear link bushes
Eircamae86 Wrote:Polybushes are very,very good,What you say makes a lot of sense, I guess the only real issue with my new bushes (not poly but harder rubber) is that any change in ride height will require that I loosen all of the bolts. Is this correct ? I have gone the harder rubber route as, from experience, the poly bushes don't last that long. An analogue brain in a digital World |
| Bushes | KSB | 3 | 867 |
12-23-2025 06:27 PM Last Post: zenki |
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 12,562 |
07-21-2014 09:12 PM Last Post: Bean |
| Wanted: Link to Beams Blacktop engine manual pdf | irishtwincam | 7 | 12,372 |
01-03-2014 11:31 AM Last Post: irishtwincam |
| Mumford link | Lajoosh | 4 | 8,780 |
11-27-2013 09:01 AM Last Post: Lajoosh |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 7,708 |
