Bushes
11-17-2025, 02:25 AM
Bushes
Hi, I’m attempting to get my 86 back on the road after almost 20 years off the road. I need to replace some bushes and will probably do them all over the next year or so. I want to keep the car fairly stock apart from a few none visible upgrades. My question is is whether to stick to rubber bushes, if available or to put poly bushes in. I understand they will firm up the handling but at the cost of ride quality. Can anyone give me an idea of how much it will be affected the ride. I also understand that poly bushes are easier to fit than the old rubber ones. The car won’t be raced. I know that flos.ie do a kit. Are they the only ones or are there others? I haven’t found any others. Cheers. Keith
11-17-2025, 08:17 AM
Bushes
Like you said, the ride will firm up when you install poly bushes. I've driven with partly installed nylon bushes (rear axle). I remember the nylon bushes to give a tremendous amount of road noise, and when I switched back to OEM, it was like night and day. I've driven with a friend of mine who installed the polybushes all around, and it was definitely way noisier than mine, but not as bad as the nylon bushes. But I also remember it giving a much more direct feel. Nowadays, mine only has the stock rubber bushings. I still have a set of Prothane in the shed, but I haven't had the urge yet to replace them.
Flos.ie sells the Prothane kit, but Powerflex also offers every bush individually:
https://powerflexstore.co.uk/toyota/corolla-ae86-rwd/
In Japan, there is no single kit available, but various suppliers (Cusco, Tecarts) offer parts of the kit.
Tecarts offers polybushes:
http://www.tecarts.com/catalog/urethanebush.html
And Cusco offers reinforced bushes:
https://shop.kts-web.com/products/116-91...ac25&_ss=r
[Image: AEU86 AE86 - Bushes]
11-17-2025, 09:07 AM
Bushes
I used slightly modified Honda Accord OEM rubber bushes for the rear end, you just have to shave the center metal bar down a bit on both sides to make them fit.
Have had poly bushes in the past and did not enjoy them for street use.
Part nr on those is FEBI BILSTEIN 41994 in case your interested. I turned them down on a lathe but to be honest its way easier and more efficient to just grab a grinder with a flap wheel to shorten them.
12-23-2025, 06:27 PM
Bushes
Polybushed mine with the prothane kit. Feels more solid and connected on the road. Mine has no sound deadening and a upgraded rear axle so the polybushes tend to send every bump/vibration/noise through the car. For regular use or just occasional cruising i’d go with decent rubber bushes.
ハチロク
  Rear link bushes totta Crolla 3 6,289 02-04-2008 12:32 PM
Last Post: totta Crolla
  signal auto bushes lsd addicted 5 7,454 05-05-2005 04:50 PM
Last Post: lsd addicted
