Rear brake discs diameter?
08-21-2006, 09:48 PM
Hello
I tried to search an information about ae86 rear brake discs diameter, but i haven't found it I measured front brake discs diameter today (it was about 243mm), but the weather became bad and it started to rain, so I couldn't measure rear discs diameter. Maybe some of you will help me and say what is the rear brake discs diameter? :wink: White ae86 Levin |
08-21-2006, 10:02 PM
These are the discs I ordered a year ago:
http://www.autopartsonline.nl/nl/ao_list...&art=27124 Quick translation: Diameter 231.0 Massive/ventilated Solid Diam. Upper part 159.0 Diam. hub 60.0 Thickness 10.0 Min. Thickness 9.0 Qty. holes other 2 Qty. wheelnut holes 4 Total Heigth 47.0 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
08-21-2006, 10:11 PM
Thanks banpei :wink:
I saw rear discs with 231mm diameter in catalogue, and i will order it tomorrow!
White ae86 Levin |
08-21-2006, 11:33 PM
cool, that's very interesting!
will have to do same to mine, cause it also needs em! talk to you on skype Nookie! adam |
| Handbrake adjustment discs? | DMC | 8 | 6,110 |
| AE86 Rear Brake options. | hachirokuGTV | 66 | 154,207 |
08-27-2016 11:01 PM Last Post: izanagi |
| Piston Diameter | Alex170984 | 11 | 20,279 |
02-07-2013 12:52 AM Last Post: fax0815 |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,629 |
| Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 18,428 |
03-03-2011 12:06 AM Last Post: filh |
![AEU86 AE86 - Rear brake discs diameter? [Image: AEU86 AE86 - Rear brake discs diameter?]](https://www.aeu86.org/sticker-banner-468.gif)
