Rear axle options
01-05-2018, 01:38 AM
Rear axle options
modception make a modified pajero axle for the AE86, but it will cost you more than 1200€ :/
you can get it in 4.875 (so close to your target of 5:1, and even shorter CWP for pajero are pretty cheap anyway)
http://www.modception.com/products/ae86/...axle-build
(They also sell a kit of brackets so you could also make your own , but that not "bolt on" anymore)
01-06-2018, 02:25 PM
Rear axle options
i would go for the weir spool, way lighter, cheap and strong than a oem welded open diff
01-06-2018, 04:01 PM
Rear axle options
weir spool require their axles and that doesn't solve the shorter ratio problem (6.7" CWP are still pretty expensive and somewhat fragile)
01-08-2018, 10:19 PM (This post was last modified: 01-08-2018 10:21 PM by ditn.)
Rear axle options
(01-04-2018 10:20 AM)Dino86 Wrote: [ -> ]@Ditn: If you have another address where I could find similar setup as yours that would be great.... or sell me yours Smile
Anyway more opinions/ideas are welcome.
Not selling mine Big Grin
I know he has a second one but its alot better than mine even with big ap brakes etc.
But it costs alot of €€
Cheapest solution is probably a volvo 2.. rear axle with a dana?/quaife lsd
  Bigger brake master cylinder options Koen 10 4,054 01-08-2026 03:12 PM
Last Post: r.ave
  AE86 rear axle weight megabob 11 26,309 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 3,599 10-24-2023 12:20 PM
Thumbs Up ITB filter options mister86 1 5,611 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 39,264 07-28-2019 08:17 PM
Last Post: harkes
