Rear Traction Brackets DIY? Dimensions ?
04-13-2010, 09:48 AM
Hi
Rear traction brackets are too simple not to DIY. Does anyone know dimensions for holes arrangement ? Do all aftermarket brackets have the same layout or some are for more and some for less lowered Hachis ? Thanks |
04-15-2010, 11:52 PM
Most brackets have the same layout for the upper part, as the axle brackets all have the holes in the same place. It's the lower your going to have to determine... I think 'most' put it about 50mm below the stock point. You can do more or less depending on how lowered you are.
04-22-2010, 02:51 PM
so does annyone have got some pictures with sizes. cause it is verry easy to make (y)ourselve
Regards, Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
04-22-2010, 02:56 PM
I'm waiting for my car to return, and will take measures. About a week.
If someone can do it faster, great
04-23-2010, 10:54 AM
Great idea.
It's very easy to cut them on digital plasma cutter and weld. Very simple detail really. owau no ka "I" |
| DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 24,630 |
| Quick question - Brake Pad Dimensions | Lt86 | 2 | 7,377 |
06-07-2015 12:08 AM Last Post: jondee86 |
| Dimensions clutch master cylinder | bozu | 2 | 8,480 |
04-16-2015 07:11 AM Last Post: bozu |
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 13,660 |
07-21-2014 09:12 PM Last Post: Bean |
| Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 29,995 |
03-13-2014 11:45 AM Last Post: Rascal21 |
