Realhachik
04-10-2010, 08:25 PM
Realhachik
this will be soon rear 4-links
![]() ![]() ![]() owau no ka "I" |
04-19-2010, 05:39 AM
Realhachik
it've finally came back to the garage.
spray anti rust on the cage before painting and some more progress - installed hood pins and assemble front break lines. ![]() ![]() next weekend I'll paint the cage and start to assemble rest of the car. now it will be with stock 4a, but soon(I hope it will be soon :wink ![]() ![]() owau no ka "I" |
04-19-2010, 01:15 PM
Realhachik
the F20C is a very sough after engine which seems to have bumped up prices to ridiculous levels. but the engine is a perfect fit for the AE86.
oh just to say those wheels are super eye candy absolute monsters ![]() ![]() |
04-19-2010, 06:36 PM
Realhachik
Hey man! Nice project!
From what dealer in US did you order those rims? And what size tires are you using? ![]() |
04-19-2010, 09:05 PM
Realhachik
thnx guys.
wheels were ordered directly from aerorace by one friend in US tyres are 215/50 bridgestone MY01 owau no ka "I" |
04-20-2010, 04:24 AM
Realhachik
boo50 Wrote:thnx guys. Are you sure the rear rims are also -11 offset? Sounds like too little for a 10" rim.. |
04-20-2010, 05:24 AM
Realhachik
I'm sure
it's really tight to fit, just 2mm from wheel to lower shock mount point. if you're gonna such wide wheels I'm recommend to got with offset -10 and less (-20 / -30 ....) always like white engine bays ) my small dream come true. ![]() ![]() and roll cage as well ![]() owau no ka "I" |
05-24-2010, 05:15 PM
Realhachik
take a vacation for a week at work to finish car.
almost finished. need only make shifter and car can move. Compbrake pedal set is really not bolt-on (can't compare with Tilton) I've a lot of cut, drill and adjust everything, even stroke on cylinders because they too long. but finally everything is working and full throttle adjusted ) owau no ka "I" |
05-30-2010, 07:22 AM
Realhachik
yesterday make a shifter
can't catch a metal-turner, so make an easy solution ![]() ![]() owau no ka "I" |
05-30-2010, 03:12 PM
Realhachik
Great work!
![]() ![]() 4AGE 16v on ITB's |
