Radiator for the 4AGZE
02-24-2012, 02:47 PM
Guys,
I'm what's the best radiator for a stock 4AGZE? I have a dual core massive rad from an old toyota but its too wide and covering most of the areas which I want to run my intercooler piping. So want to change. Any suggestions? A Civic 2 row like this would work?? http://www.ebay.com/itm/ALUMINUM-RADIATO...5890bc0e1e thanks. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
02-24-2012, 03:14 PM
core size seems rather small to me - I'd measure up how much space you need for the piping and then fit the biggest possible you can find... there's no such thing as too big of a radiator - especially in hot countries.
AE86 ex-daily |
02-24-2012, 03:23 PM
This civic radiators are commonly used in staret turbos, running high turbos and with output usually more than 220hp with no real problem.
I'd say that should be enought for a stock 4agze... Also why not use a 76c thermostat? Japan 4 Ever |
02-25-2012, 10:15 AM
Try one from a Hyundai excel, should be an easy fit and works fine for my engine, i've got a turbo'ed 4agze
AE86 Levin |
| Radiator & grill support panel (Levin) | FanIsHere | 5 | 4,978 |
11-14-2022 10:07 PM Last Post: Ivan141 |
| Alu thick core radiator fitment | Gtsi-R | 5 | 5,732 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
| AE86 F20C swap - Radiator issue | mad.matt | 3 | 8,286 |
02-07-2018 05:14 PM Last Post: mad.matt |
| Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 8,303 |
06-23-2017 05:21 PM Last Post: pack |
| cool lower radiator hose | thanos | 4 | 7,924 |
11-29-2016 01:06 PM Last Post: thanos |
