RPM too high on the clock's
12-15-2008, 04:08 PM
Hi, my 86 look's crazy.
With the engine at the ralenti 850 rpm (+/-), on the clock's it show's 1800 or 2000 rpm.
The clock's are OK, confirmed.
Do you know where the problem is?
Regards
12-15-2008, 07:18 PM
Why are you complaining? Now you can take some pictures and show everyone your car does 10000rpm!
Ralenti = idle
Hurray!
12-15-2008, 08:24 PM
Where did you get the 850 rpm reading from?
12-16-2008, 12:37 AM
IVAN141 Mechanic did. I don´t know how...
Sideways? Just for fun... not a way of life.
12-16-2008, 10:21 PM
Either your running some strange ignition that is not supposed to be there, or the 850 rpm reading your mechanic got is wrong.
The AE86 gets it's tacho signal straight from the coil if I'm not mistaken, so there is not a hell of a lot that can go wrong there if the car is still running good.
At 850 rpm, the engine should run in a relaxed manner, the difference to 1800 rpm is pretty big so you should be able to notice the difference. Does it idle quietly and smoothly?
How did you confirm the proper working of the clocks?
12-16-2008, 10:50 PM
Ivan141 Wrote:At 850 rpm, the engine should run in a relaxed manner, the difference to 1800 rpm is pretty big so you should be able to notice the difference. Does it idle quietly and smoothly?
Indeed ,it's a huge difference between 850 and 1800 rpm,you can clearly notice it by listening to your engine.
ハチロク
[Image: AEU86 AE86 - RPM too high on the clock's]
12-17-2008, 12:01 AM
Hi, maybe I didn't explained too well the situation.
When the engine is running idle 850 rpm (+/-) on the clock's it shows 1800 or 2000 rpm, or when running in 5 gear the RPM on the clocks are about 8.000 rpm...
I'll post a video soon.
Regards
12-17-2008, 12:29 AM
... warmup? The 4age runs around 1800-2000 when started. When the engine warms up it drops. Normal cars idle @ 600-1000 straight away but some japanese cars don't. (specially the sporty ones)
get a new mechanic
12-17-2008, 01:00 AM
This situation happends with car cold or warm.
http://www.youtube.com/watch?v=YlK49-GXVcQ
12-17-2008, 01:26 AM
Thumbs up! lol ok thats not good. you switched to 4th gear in the movie? that should be around 5k rpm @ 140kmh
  Blacktop 20V high idle Bravothreezero 2 149 08-10-2026 04:58 PM
Last Post: ondafly
  High-beam warning lamp Mylesmck 4 4,149 07-21-2023 07:44 AM
  No idle below 2000 rpm rich running Steller Engineering 3 3,697 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine stress at high speeds gh0st 6 5,750 08-30-2022 07:11 PM
Last Post: Power_uP
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 13,503 07-28-2022 10:48 PM
