Question to the self-mapper among us: AFR target ?
09-06-2010, 07:06 PM
?????? Big Grin
[Image: AEU86 AE86 - Question to the self-mapper...R target ?]
09-08-2010, 12:20 AM
I think you would want to be a bit richer on full boost... 12:1 or
maybe even 11.5:1 @ 1 bar.
Cheers... jondee86
09-08-2010, 09:45 AM
I went for:
And this is the result according to LC-1
12 or lower sounds too much for NA. That's ok for Turbo.
09-08-2010, 11:19 AM
I am not familiar with the program CROME. But looking at the graph,
it seems that columns 1 - 5 are vacuum, and TP6 - TP10 are boost ??
If this is so, and you are considering only NA, then only the columns
1 - 5 are available for your selection. And of course if you are considering
only NA, then 12.7:1 or close would be fine for max rpm/load.
Cheers... jondee86
09-08-2010, 11:22 AM
This is NA, no turbo, no boost Smile
Horizontal line is engine load.
ECU is set to use MAP under 25% of TPS and after that TPS.
So, columns 1-5 are MAP readings, and 6-10 are TPS.
Vertical is engine speed, of course.
09-08-2010, 03:17 PM
Hi,
Normally you should run your engine with lambda 0.90, this is the best value for performance.
But for sure you can only check it on a dyno.
Mine engine needed lambda 0.87 under full load.
When you have a cat you should map lambda 1.00 (in part load).
The reason for this is that the cat only works in a small range around lambda 1.00
A simple rule:
For performance you need lambda 0.90 and for economics you should map lambda 1.10.
Full load, best performance between 0.90 – 0.88.
I hope this helps.
Ron
09-08-2010, 06:05 PM
You can run pretty lean in low load cruise conditions... saves a bunch of fuel.
Somehow I doubt anyone here would ever try that though.
A Prius for instance runs 1:17 under such conditions if I remember correctly.....
09-08-2010, 07:37 PM
Is there any EGT info? Just installed an EGT meter (leftover from a previous project) and under light city driving conditions (40-60km/h under 3k rpm in 5th) it shows 350-450 celsius, on the motorway it shows around 600-650 3500-4000rpm up to 130km/h. Are these values normal? The engine is stock bigport map close to it's end of life. Smile
http://www.ae86.hu
09-08-2010, 11:29 PM
Uzelac Wrote:Horizontal line is engine load.
Ahhh... now I understand Smile Nice way to get MAP/TPS blend.
Cheers... jondee86
09-09-2010, 09:40 AM
Ivan141 Wrote:You can run pretty lean in low load cruise conditions... saves a bunch of fuel.
No worries, will try, as soon as i get EGT sensor Smile
  Question to the self-mapper among us: Knock detection? MartinS 8 10,028 07-09-2010 10:04 AM
Last Post: Speedline
