Question about raising compression?
01-28-2005, 09:56 AM
2 PetzK:
These $200 wheels are fancy items. I think - ZaX uses homemade ones made from stock wheels - he replied to me with the pictures - and the wheels were not bad. Another option are "vernier" type - just redrilled wheels. About angle correction - depends of head shaving and cams - can be even 2-3 degrees! Again - I said that these are not obligatory, just improvment. If you could fabricate them up to 20EU per set (the set of used stock ones is $5 @ebay) - this is fine upgrade! |
01-29-2005, 04:18 AM
[/quote]ZaX uses homemade ones made from stock wheels - he replied to me with the pictures - and the wheels were not bad.
Quote:Can you send me the pics, please |
01-29-2005, 03:19 PM
2 Mulisha:
With pleasure: |
01-29-2005, 06:07 PM
Thats awesome. I assume you have to get a machine shop to make the inner pieces or is there a special piece that can be found somewhere else?
01-29-2005, 11:05 PM
I prefer to cut the stock wheel and use inner and outer parts with additional O-plate to insure adjustability. That way machining will be required for cutting and for the O-plate only. Will provide pictures when I'm done.
01-30-2005, 11:37 AM
I think I know what you mean, but wouldnt that decrease structural rigidity a bit more?
01-30-2005, 12:08 PM
2 Ivan141:
Depends of thickness and quality of steel, used to fabricate the O-plate. If you use stainless one (for example) - it will be the strongest part of the modified wheel. I can use also 4-point bolt-joints for internal joint (take a look at the stock wheel - if I use the 6 bolts, there will be some weakness near to the central hole). The outer bolt-joint will be 3-point - as shown to previous (Zax?) pictures. Offcourse one-piece wheel is more structural rigid but there is no way to make adjustable one-piece timing wheel (except "vernier" ones). PS: When fabricate, I try to use quality materials. If possible - to exceed specifications of the stock ones. |
| 82mm Stock compression Pistons | apardal | 4 | 5,563 |
| working out compression ratios | kazi | 2 | 5,794 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
| Raising the rev limit on stock ECU | fax0815 | 2 | 13,989 |
08-31-2015 02:04 PM Last Post: gon |
| What is cranking compression on 10-1 4AGE? | oldeskewltoy | 2 | 6,866 |
03-24-2015 10:18 AM Last Post: ditn |
| What fuel are you high compression guys running? | 4000GT | 18 | 23,348 |
09-04-2011 07:11 PM Last Post: IBMFD3S |
