Propshaft
04-13-2005, 05:55 PM
Propshaft
Is the propshaft hardened? Or are basicly all car propshafts of hardened steel?
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - Propshaft]
04-13-2005, 06:33 PM
Propshaft
who cares! Tongue
you will need some 700 horses to break it Hurray!
04-13-2005, 08:13 PM
Propshaft
I really need to know.
04-14-2005, 01:24 PM
Propshaft
Aico, my opinion - no. They are only well balanced.
04-14-2005, 01:39 PM
Propshaft
I'll just take your word for it then. I hope you are right, because you can weld non hardened steel. Makes things easier for me.
04-14-2005, 01:45 PM
Propshaft
let me guess you need to adjust it cause of thegearbox of the CA18det engine. Good luck with the electronics
Propshaft
Aico, just keep in mind to use non-sewed tubes.
04-14-2005, 02:19 PM
Propshaft
It's just for shortening the shaft. The shaft needs to be welded to the U-joint.
  Changing propshaft bearing. Anything I need to know? Lauren 5 11,008 04-15-2012 02:12 AM
Last Post: krullibull
  Propshaft options Jezza_hr 7 9,645 10-15-2010 05:22 PM
Last Post: Hachi
  rear diff/propshaft clanking/banging at low speed Uzelac 5 7,502 06-20-2010 02:03 AM
Last Post: Uzelac
  Propshaft. 205t16 8 9,976 08-22-2006 07:17 PM
Last Post: 205t16
  Centre Propshaft Bearing - How much play is too much ? Ian.G 4 6,359 10-17-2005 08:53 PM
Last Post: richieu
