Problem exhaust drone: Solution 1/4 wave, or Helmholtz resonator?
05-16-2017, 09:09 PM
Problem: engine drone 3500-4000, it is quite bad through that zone, so lets say 3750 rpm + or - 250 rpm.
I've been doing some research into side branch or 1/4 wave resonators - closed "J" shaped pipe of SPECIFIC length added to the system. ![]() Some people also use Helmholtz resonators (pipe leading into closed muffler) Each of these has their own formula (no, I have not researched each's formula yet) The reason I have not checked into both thoroughly yet is packaging of a Helmholtz resonator, and placing which ever device in as optimal a location** as possible - close to the source/engine. So based on optimal placement, I was thinking of tapping into the very beginning of my Brave exhaust with a 1.50-1.75" diameter pipe, and running it the prescribed/calculated length back.... ![]() Initial distance is around 30"... or so I was told. I don't trust this - I'd prefer YOUR help with calculations... So what length pipe do I need to target 3750 rpm?? Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-17-2017, 11:05 AM
Just make sure it's not the exhaust vibrating against something that's causing the drone.
Read a whole topic on these resonators on some porsche forum out of interest, and in the end after much faffing about with resonators the problem turned out to be the exhaust mounting. FABRICA MI DIEM, PVNC! |
05-17-2017, 01:47 PM
(This post was last modified: 05-17-2017 01:56 PM by Dave W.)
Dan
See if you can get a copy of "Scientific Design of Exhaust and Intake Systems by Philip Smith & John Morrison" from your local library. The location of the "J" pipe in the system and distance from the muffler will effect the resonance frequency as much as the length, i.e. volume, of the "J" pipe. They appear to be most effective when install right after the exhaust manifold. Dave W |
05-17-2017, 05:08 PM
(05-17-2017 01:47 PM)Dave W Wrote: Dan still doing research....... http://www.f1technical.net/forum/viewtopic.php?t=12772
05-17-2017, 11:23 PM
(This post was last modified: 05-18-2017 12:32 AM by jondee86.)
I have wondered if something like this could be implemented on a 4AGE ?
![]() Quote:A four-stroke power valve is a device fitted to four-stroke engines that It might even be a solution for the mid-range drone ![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
05-17-2017, 11:36 PM
(This post was last modified: 05-17-2017 11:37 PM by Bean.)
Have the closed of part of the pipe as a sleeve going over the rest of the construction. That way you'll be able to adjust the length until you get it right.
It will take quite some time testing but honestly no amount of calculations will get it right. The calculations will only give you a starting point, as there are way to many factors involved which you can only approximate for. AE86 ex-daily |
| Exhaust fumes in cabin (Hatch seal problem!) | Lt86 | 16 | 24,636 |
11-13-2015 01:20 PM Last Post: pack |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 44,281 |
| AC problem? Idle problem? | KD2229 | 3 | 5,922 |
08-19-2009 02:08 AM Last Post: KD2229 |
![AEU86 AE86 - Problem exhaust drone: Solu...resonator? [Image: AEU86 AE86 - Problem exhaust drone: Solu...resonator?]](http://i59.tinypic.com/53pdmf.jpg)
![AEU86 AE86 - Problem exhaust drone: Solu...resonator? [Image: AEU86 AE86 - Problem exhaust drone: Solu...resonator?]](http://ost.ebeans.ch/albums/userpics/10005/quarter_wave_resonator_idea.jpg)
![AEU86 AE86 - Problem exhaust drone: Solu...resonator? [Image: AEU86 AE86 - Problem exhaust drone: Solu...resonator?]](https://enoanderson.com/wp-content/uploads/2014/04/exup-system-2.jpg)
