Pics wanted
12-17-2004, 09:13 PM
Pics wanted
I think problem is solved
Was a crack in the top of ignition coil (plastic bit). It is a very thin crack , hairline. A new coil has been ordered and will be fitted tomorrow. I will let you know the results. Cheers |
12-17-2004, 10:02 PM
Pics wanted
330 sounds promising
12-17-2004, 11:28 PM
Pics wanted
nahh... my friend had a similar problem.. just use ducktape =)
12-19-2004, 04:34 PM
Pics wanted
Quote:nahh... my friend had a similar problem.. just use ducktape =)I was told ducktape would not hold 40,000 VOLTS Ive changed the ignition coil and the car is better but not perfect. Is there anything else I have to do after changing ignition coil ? What else can I try ? Im getting there so Im a little happier
