PROPELLER SHAFT Problems
03-29-2009, 03:12 PM
PROPELLER SHAFT my AE86 is unbalanced when I go over 80k/hy get the car started vibrating in neutral how can i resolved this buying a new PROPELLER SHAFT where i can find it ?
one more question what type of Shaft is used by the GTS ? for example in the ECP Part the have 2 Diferents type of Shaft 1 - PROPELLER SHAFT & UNIVERSAL JOINT 3 jOINT Type 2 - PROPELLER SHAFT & UNIVERSAL JOINT 2 JOINT Type i put a 4AG with T-50 Trans |
03-29-2009, 03:49 PM
you need the 3 joint type
http://www.toyodiy.com/parts/p_E_1984_TO..._3701.html |
03-29-2009, 04:26 PM
ok, but my car is not the GTS
is a SR5 Automatic i make the swap of the engine this can work / |
| Big wheel problems | gh0st | 16 | 16,544 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 5,401 |
| Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 11,345 |
| Steering shaft issue | Ryo | 15 | 19,710 |
11-19-2018 09:52 AM Last Post: Ivan141 |
| Problems Mintex M1155 pads | Dino86 | 9 | 13,940 |
07-04-2017 11:22 AM Last Post: totta Crolla |
