PLEASE - SUPERFAST HELP REQUIRED - PICTURES
05-30-2005, 11:18 PM
What does this "THING" do for the clutch-oil.
It it fitted 20cm before the clutchcylinder that pushes on the clutch itself.
this item also has it´s own bleeding screw & it has anshort rubber line into & out of it which supports the clutch-oil - if I remove this thing i´d be able to fit an single clutch-line all the way from the clutchmaster-cylinder = MUCH better than stock.
WOULD THIS BE POSSIBLE ?
05-30-2005, 11:54 PM
kris i wouldn't do it...... its there not for nothing.... i've never seen this MOD on a AE86. If you go time to exchange it twice you can test it but i wouldn't recommend it without consulting race build AE86's
05-31-2005, 08:37 AM
Don't have that thing on my car.....
05-31-2005, 08:41 AM
I think it's just what you can see from the outside...a bleed valve. Especially if it's mounted in the top of a loop. But dont go guessing, try looking it up in EPC, I cant help you out since I'm at work..
05-31-2005, 10:34 AM
thanxs - I have just learned what this is..
It´s a extra bleed valve / restrictor för the clutch-oil.
the restrictor allows for a smoother clutchslip.
just remove it i have been told
kris
  TUV RHD AE86 Germany (help please) 4dori 9 8,521 07-17-2019 07:42 PM
Last Post: Hachigo83
  Detailed LHD engine bay pictures Bean 0 3,525 08-05-2018 04:09 PM
  Carb question please help MIGGZFSU 3 5,570 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Whining noise HELP PLEASE izanagi 10 14,028 03-26-2015 06:48 PM
Last Post: Komba
  the connector saga (please help everyone) Bean 8 10,662 06-23-2014 01:13 PM
