Outer TIE RODS - interchangeability?
08-10-2010, 04:21 PM
I need new outer tie rods fast and since ae86 isnt common here stores might have other tierods in stock (other toyotas etc.). According to the original toyota epc, none are the same, but according to some other catalogues, others should fit (newer corolas, carinas,celicas etc). Is this true? Which can i use?
08-10-2010, 04:42 PM
whats the OEM part number?
try here http://ekataloghr.intercars.com.pl/
or here http://www.elitcar.com/catalogs/index.ht...0&mdf=3475
if u can find the part u can see other cars it was used on...
08-10-2010, 04:49 PM
http://www.technotoytuning.com/productdetail.php?p=739
why bother with orginal if you can get better ?
08-10-2010, 08:28 PM
KE corolla stuff fits 79-84 or so RWD. Probably not much help but its a start.
Ebay.de has ae86 ones..but it'll take some time. Why the hurry?
08-10-2010, 08:53 PM
im eagerBig Grin its been 4 years, o boy i hope it runs. tomorrow i start up the engine for the first time ssince rebuild. fingers crossed! Hurray!
08-11-2010, 01:34 PM
Ok Apolan, you owe me big time Smile
OEM NO.
45046-19175
45046-29305
Toyota Camry (V2) 10.86-05.91
Toyota Camry (V20) 08.96-11.01
Toyota Camry Station Wagon (V2) 11.86-05.91
Toyota Carina II (T15) 10.83-05.88
Toyota Carina II Stufenheck (T15) 10.83-11.87
Toyota Celica (T20) 11.93-11.99
Toyota Celica Cabriolet (T20) 04.96-11.99
Toyota Celica Coupe (T1Cool 10.89-01.94
Toyota Corolla (E10) 07.92-04.97
Toyota Corolla (E9) 08.87-06.93
Toyota Corolla (ECool 06.83-05.88
Toyota Corolla Compact (E10) 07.92-04.97
Toyota Corolla Compact (E9) 08.87-04.92
Toyota Corolla Coupe (AE86) 08.83-07.87
Toyota Corolla FX Compact (E8B) 01.85-05.88
Toyota Corolla Liftback (E10) 07.92-04.97
Toyota Corolla Liftback (E9) 08.87-04.92
Toyota Corolla Liftback (ECool 06.83-05.88
Toyota Corolla Wagon (E10) 04.92-04.97
Toyota Corolla Station Wagon (E9) 12.87-06.92
Toyota RAV4 I (SXA1) 06.94-06.00
Its from the internets, so check before comitting to something
08-11-2010, 06:27 PM
OEM No. for the outer tie rods is definately
45460-19125
i know they are interchangeable with other Toyotas and also Daihatsu Charmant A
i bought some from ebay and they do fit
08-11-2010, 06:36 PM
Good news i got it! By an act of god might i add through a sequence of highly unlikely to happen events, they had 1 piece in stock Big Grin
NoHachi much appreciated! But according to EPC the part code is 45460-19125 which is only found on AE86's and some other rwd oldie toyos like the kp6x and ta7x.
Interestingly i found that exact part number, the one you listed - to be a perfect match via some other catalogues, but i checked the part and it is different - usually much shorter and with the outer stopping nut.
anyway all is good, i got the part!
thank you all for the help, hope somebody can clear up this confusion with those numbers.
@Robo: yeah the t3 stuff is nice, but is also 6 times more expensive + shipping. I got this part for 20 euros.
  Trueno - Headlight Rods pack 16 18,805 04-27-2012 11:23 AM
Last Post: pack
  Forged rods for 4AGE 20v options 4000GT 12 22,109 07-17-2011 08:50 PM
Last Post: Jimmi The Kid
  Headlight interchangeability Ivan141 10 16,462 05-09-2011 10:10 PM
  Longer Tie rod / steering ends meshin 2 7,655 11-10-2010 01:57 PM
Last Post: meshin
  I need rods 40mm crank journal, and 20mm wrist pin!!!! filip.alin 4 10,948 11-04-2010 06:57 AM
Last Post: filip.alin
