Oil pressure switch?
04-30-2006, 09:54 PM
Does the 4AGE have an oil pressure switch fitted to it. I have a oil pressure gauge, but want to remove it for a switch, anyone know what thread it would be.
Cheers
BYD
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
04-30-2006, 10:06 PM
hmmm..maybe another toyota oil pressure switch will fit..most models came with a switch, so I wouldnt be too surprised if other 'A' block pressure switches fit without problems. Try a 4AC or 4AF engine...The thread on the pressure sender on the 4age is some weird NPT style gas-fitting thread I think, not sure what it is exactly.
04-30-2006, 10:15 PM
This the one you are looking for? Dumb question
http://www.aeu86.org/viewtopic.php?t=1395
[Image: AEU86 AE86 - Oil pressure switch?]
05-02-2006, 04:25 PM
The threaded hole for the switch/gauge (4AC/4AGE) is conical !
05-07-2009, 10:53 PM
yesterday I changed the header and today I realized the oil pressure gauge says zero, empty, but there is oil in the engine. so must be a oil sender issue, what could I have done wrong changing the header? is there a wire going to the sender? I didn't find a connector...but it was very dark...
05-07-2009, 11:51 PM
The sender is below the headers, to the left of the oil filter. The wire to it is just a slip on one so you probably knocked it off without noticing.
05-08-2009, 08:35 AM
ok found the loose wire and connected it to the top of the sender, it works! thanks!
05-09-2009, 12:47 PM
had the same problem, but mine still wasnt working after i connected it..we'll see how it oes after i fire the engine up after rebuild.
  Ignition switch plug and wires Blaze0010 3 2,988 11-25-2024 12:29 PM
Last Post: Blaze0010
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 25,341 08-19-2018 12:08 PM
Last Post: AlexKTM
  Oil Pressure Query Alex170984 2 6,515 12-11-2014 01:25 AM
Last Post: Alex170984
  trans oil, lsd oil change Apolan 9 21,147 10-01-2014 03:57 PM
  removing light switch ? (fixed) MC_JP 10 20,691 09-18-2014 05:16 PM
Last Post: MC_JP
