Oil from head to air collector in 4age when drifting left.
04-24-2008, 11:25 PM
Need your help! I've got very high compression ratio in my 4age (about 16 bars), and when I'm drifting left oil from head goes to air collector and leaks from air filter. The cable that you see in red circle on the picture was straight and it was TERRIBLE. Now it's a bit better, but still not good. Anyone had problem like this, how did you solved this?
[Image: AEU86 AE86 - Oil from head to air collec...ting left.]
Thanks a lot!!!! Respect! Respect! Respect!
04-24-2008, 11:58 PM
Been covered many times... search and you will find Smile Basically you
need to take that hose into a "catch can" to separate the oil, then take a
vent hose back to the inlet manifold. Use a sealed can with a level tube on
the outside, and empty the can when you have half a litre of oil inside Smile
You can buy a catch can from a car accessories store, or make one
yourself if you have some tools. You can easily see how they are made
by making a search on the web.
Cheers... jondee86
04-25-2008, 12:19 AM
Thanks a lot!! I thought that it was only in my engine Wink
thabks! Respect! Respect! Respect! Respect!
04-25-2008, 08:24 AM
this is new to me. I always wonder why my intake manifold was really diry in the first place.
anyone got a pic of a good fiting for this. Im going to research this.
East Coast Toyota
http://ectoyotas.com/forum/index.ph
Club4AG
http://www.club4ag.com/
04-25-2008, 01:47 PM
Discharging oil into the intake requires two things... sustained high
rpm to pump a lot of oil up into the cam covers, and a long, high speed
left turn. This "centrifuges" the excess oil over to the right of the head
where the crankcase vent is located. It is then blown out the vent tube,
and finds its way into the air intake.
Usually only a problem with the TVIS bigport motors, as smallport and
later motors had better oil drains from the head.
The tube that you see entering the side of the plenum is channeled
internally up a duct that vents into the intake just in front of the throttle
butterfly. Some will get sucked into the engine to make smoke Tongue Some
will drain down to the filter.
Google "Cusco" or "Greddy" and "catch can" to see two examples of a
universal sealed can. There are other cheaper ones around, available
from auto parts supermarkets.
Cheers... jondee86
04-25-2008, 03:16 PM
just swap the cam covers around ......
04-25-2008, 09:43 PM
What gon said is the best idea... just swap camp covers left to right and run a catch can if you want.
  Fitting Air Con (No PS) to LHD AE86 pack 7 5,913 01-07-2024 11:36 AM
Last Post: CCB
  4AGE cylinder head plug removal Ivan141 5 3,441 09-30-2023 09:47 PM
  Inside of front wheel touches frame rails during drifting bozu 3 2,869 06-09-2022 04:51 PM
Last Post: Project D
  Air Cleaner Assembly Hama86 7 10,834 10-29-2018 03:28 AM
Last Post: Hama86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 20,815 08-16-2018 01:36 AM
