Oil breakdown
08-17-2005, 08:16 AM
Oil breakdown
Kas,
I use semi-synth Motul at the moment (the Motul importer is near to my home).You don't need to change oil every 7000 km when using semi/full synthetic oils - except if you drive only in the town.
PS: The 4100 Power Motul costs only 4EU/l here - pumped from the barrel.
08-17-2005, 08:45 AM
Oil breakdown
.... type of oil has no RPM linked to it. I know a racing 4age running on full synth at 9700 rpm. Its just the thickness of the oil with temperature and stuff that indicates
10w-40
Besides that if the engine oil pressure drops doesn't mean that its not running fine. I have had the same problem many times but in time it corrects itself.
but rpm has no indication of oil how thick it should be. Thickness comes with weather i believe 10w is for -10 or somthing and 5 is -20 i believe so thats more for austia etc
08-23-2005, 02:41 PM
Oil breakdown
I change oil to Mobil 5W40, no more smoking, no oil eating. I drowe about 150 km at 5000 rmp, and it is loking good.
What is your temp of oil when running in town, and at freeway?
Mine at city about 90-95, and at freeway about 100, maybe 105.
My sensor is on pipe which lead oil to oil cooler.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
  trans oil, lsd oil change Apolan 9 22,724 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 41,481 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 11,225 10-01-2011 09:47 AM
Last Post: demogun
  Oil Presure and what oil i have to use? CHACAMAN 4 8,132 08-27-2008 05:35 AM
Last Post: F0Bman
  High engine oil temps - oil cooler discussion SutteR 28 34,916 06-08-2008 11:23 PM
Last Post: eight-six
